Replacing A Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 02:07 PM   #1
Replacing a circuit breaker
Hey,
Is it safe to replace a circuit breaker (inside a circuit box inside our condo) if I follow the following steps.
1. Turn off all of the circuit breakers.
2. Turn off the main circuit breaker (inside).
3. Turn off the main breaker (outside box).
4. Test the wires going into the circuit breaker I want to remove for current.
5. Wear protective eye wear and gloves.
6. Remove the circuit breaker in question avoiding touching any electrical connection points or wires.
7. Replace new circuit breaker and reconnect wires.
8. Test.
The ones that I want to replace I have been told (by an inspector) that they can cause a fire (they are labeled red).
I have done my fair share of electrical work, but not replacing a circuit breaker except for seeing it done.
* I'm not an electrician.
T
tertius is offline   Reply With Quote
Old 09-24-2009, 02:14 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 150
So you have an FPE breaker panel.
Are you having trouble, or just afraid of what the inspector said?
jbfan is online now   Reply With Quote
Old 09-24-2009, 02:43 PM   #3
Yes FPE.
Nope, we haven't moved in yet. I'm not scared, just making 100% sure that it's safe and I'm not jumping into something dangerous and missing something.
Old 09-24-2009, 04:11 PM   #4
jbfan's Avatar
Rewards Points: 150
Unless you are in Canada, just replacing one or two breakers is not worth it.
You need to consider having the entire panel replaced.
The whole panel and all the breakers are a problem, not just the red handle ones.
Old 09-24-2009, 04:21 PM   #5
I'm willing to go that far.
Can you explain why?
Thanks for the response so far
Old 09-24-2009, 04:27 PM   #6
jbfan's Avatar
Rewards Points: 150
Here is a link that explains it better than I can.
http://www.inspect-ny.com/fpe/fpepanel.htm
Old 09-24-2009, 04:43 PM   #7
Thanks for the link, good to have more info on the specific hardware that I'll be buying as part of the condo.
You said that it's not worth replacing the red ones. Is it just too risky? Are the parts hard to get a hold of?
Also, if you'd be so kind, explain to me what the risk is with the red ones. (The inspector did only briefly).
Old 09-24-2009, 04:59 PM   #8
jbfan's Avatar
Rewards Points: 150
I don't know any specific reason the red handles are more or less dangerous than other color handles.
What did the inspector say?
I have not dealt with too many FPE breakers.
Maybe this can be a bargaining tool for the purchase.
Old 09-24-2009, 05:11 PM   #9
He said there was a fire danger with overvoltage. I'm not sure the term he used was overvoltage.
The red ones don't have protection for it but the others do.
They are fine, not needing replacement. But essentially just a precaution.
Old 09-24-2009, 09:17 PM   #10
The danger is due to these breakers not tripping when they should. In the event of a circuit failure such as a short, the can continue to feed power to a faulty circuit and you end up with a fire. They can also simply overheat and set themselves on fire.
I have first hand experience with an FPE breaker failure, and honestly came very close to loosing a house because of it. Had I not arrived on the scene and killed power to the box, there would have been a fire.
They are unsafe, and the entire panel should be replaced, especially in any kind of multi-family structure. I wouldn't ever even consider moving in to a condo if any of the units were using an FPE panel.
KAdams4458 is offline   Reply With Quote
circuit breaker problems nascarstewartfan2007 Electrical 8 09-13-2015 10:11 AM
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 10:47 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Replacing 15 amp breaker with 20? kcrossley2 Electrical 13 07-22-2007 05:29 PM
