Replacing Ceiling Fan - Not Going Well! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 11:11 AM   #1
Replacing Ceiling Fan - Not going well!
Greetings!
I'm hoping for some help, I am replacing an old ceiling fan with a new one that has a remote control function.
I discovered in the box on the ceiling there were three wires coming in and capped off with a wire nut. The previous fan was wired to two other white wires coming in, and the fan is on a switch.
The problem is when I wire the new fan the same way the old one was, it does not have power.
When I wire it to the three capped off wires instead, no power either.
When I wire all of them together (gasp!) It shorts out at the breaker.
Any ideas on how to wire this thing?
Thanks!
Waterfroggy is offline   Reply With Quote
Old 04-24-2012, 11:18 AM   #2
Licensed electrician
Rewards Points: 1,876
A picture and the colors of the connections you made would be helpful.
Old 04-24-2012, 11:32 AM   #3
Rewards Points: 2,516
I dont understand. You say three wires were capped at the ceiling and the previous fan was wired to two other white wires coming in.
If the 3 wires that were capped were not being used in the old set up, why would you introduce them into the new setup?
Determine which wire at the ceiling is switch controlled.
Do you have a meter to measure voltage?
hammerlane is offline   Reply With Quote
Old 04-24-2012, 11:57 AM   #4
silly question: when the new fan was wired up the same as the old, you did have that existing fan wall switch in the 'on' position while trying to use the remote, correct?
itsnotrequired is offline   Reply With Quote
Replacing a dimmer switch with a regular switch for a ceiling fan RP DeMars Electrical 0 04-18-2012 03:25 PM
Replacing Basement Drop Ceiling w/Drywall sadic1 Remodeling 17 03-18-2012 10:23 AM
Replacing garage 2x4 ceiling joists PAY22 Building & Construction 2 10-30-2010 03:50 PM
replacing bathroom ceiling heater... DIYDI100 Electrical 2 01-09-2010 08:34 PM
Replacing drywall ceiling only, not walls shan1616 Drywall & Plaster 10 11-15-2009 03:15 PM
