Replacing Ceiling Fan Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 01:46 PM   #1
replacing ceiling fan light switch Please help
I have a ceiling fan with separate switches for the fan and the light. The fan is fine-or was before I tried to replace that light switch. I removed the old switch and connected it exactly as it was. The exception being that the previous switch was connected to the light socket at the factory. I had to use a different mounting bracket to connect to the housing. I connected the wires and the bracket to the same screws. Now neither the fan or the light work. Did connecting the bracket to the same screws as the light wires mess this up? There are only 2 wires that come from the housing. One white and one blue. Any help will be greatly appreciated.
bluesdawg is offline   Reply With Quote
Can Any Ceiling Fan Work With A Dimmer Light Switch BlessedMomma Electrical 10 01-25-2011 06:45 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Replacing an old porcelain ceiling light socket bellzerr Electrical 2 09-29-2010 03:54 PM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 08:14 AM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
