Replacing Capacitor In Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 04:21 PM   #1
Replacing capacitor in fan
I have a ceiling fan that I like, it cost almost $200 and it moves a LOT of air.
The problem is that the high speed doesn't work anymore, only medium and low. The fan has a remote and receiver hooked up to it, but I bypassed the receiver to test it out and make sure that it wasn't the receiver that was bad- it wasn't.
After doing some research, I found that this fan is prone to losing a speed or two due to capacitors dying. The manufacturer is of no help if you are out of the warranty period, tho.
Is this something that I can fix easily? Or should I just get a new fan?
Thanks!
Macro is offline   Reply With Quote
Old 05-28-2012, 05:48 PM   #2
Price out a new cap. If the fan is $200 and a cap is less than $20 it is probably worth it the gamble.
But you can check the cap several ways without using a cap checker, with a few bucks in parts from Radio Shack.
Old 05-28-2012, 05:54 PM   #3
Can i check the cap with a Fluke 112?
Old 05-28-2012, 06:00 PM   #4
According to page 7 of
http://www.testequipmentdepot.com/fl...1-112_manu.pdf
yes.
Rather than cap checking I opted for the B&K 391.
If it's not the cap, some fans have a potted multispeed module. You could price this out also.
Replacing rotted sill plate in 120 yr old home M.dizzle Building & Construction 16 02-29-2012 02:53 PM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 07:57 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 04:08 PM
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
