Old 09-26-2010, 06:30 PM   #1
replacing a breaker
can you replace a gfci crouse hinds breaker 20amp with a regular 20 amp siemens breaker? is there a compatibility issue if you have a gfci breaker and also gfci outlets in the room the breaker supplies?
lgburke is offline   Reply With Quote
Old 09-26-2010, 11:36 PM   #2
replacing a breaker
You have to see if the replacement breaker is approved for your panel.Check label on panel door.Gfi breakers can supply a gfi device.
bobelectric is offline   Reply With Quote
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 07:17 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 11:53 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
