Old 01-09-2013, 11:51 PM   #1
replacing a breaker
how much it cost to replace a 2 pole 20 amps breaker
alexvera is offline   Reply With Quote
Old 01-09-2013, 11:58 PM   #2
replacing a breaker
Why does it need changing?
Why not change it yourself?
It's about a 5 min. job.
Old 01-10-2013, 12:18 AM   #3
DIY Enthusiast
sublime2's Avatar
replacing a breaker
If you don't know what your doing, it can cost you your life.
sublime2 is offline   Reply With Quote
Old 01-10-2013, 08:14 AM   #4
Licensed electrician
replacing a breaker
Depends on the cost of the breaker and who does it.
Old 01-10-2013, 08:48 AM   #5
replacing a breaker
The breaker itself is about $8 at HD. It can be done very easily if you have any common sense. You should kill the main breaker before touching anything. If you don't know what you're doing then you could easily kill yourself.
If you're asking how much an electrician should charge, I would guess they'll charge you an hour. No idea what electricians in your area charge for an hour of work though. Guessing $60-$120.
mikegp is offline   Reply With Quote
Old 01-10-2013, 09:01 AM   #6
replacing a breaker
The OP did not state if the breaker was one that is currently available off the shelf or if it is a hard to find obsolete one so pricing cannot be given for the part.
Any contractor charging rates like that will not be in business long.
Old 01-10-2013, 10:14 AM   #7
Lic Electrical Inspector
electures's Avatar
replacing a breaker
$9986.21. If you pay me cash I'll do it for half.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 01-10-2013, 10:39 AM   #8
replacing a breaker
Electricians charge less than $60 an hour? Just driving to you costs gas, wear and tear, time, insurance, and other overhead. I doubt I could even get an electrician to take that job in my area. It's not worth their time. Mechanics in my area charge $90-$150.
Old 01-10-2013, 01:30 PM   #9
replacing a breaker
My go to plumbtrician is a steal at $90.00 an hour. He shows up on time, knows what he's doing so doesn't waste time, is clean, neat and personable and is supportive of my DIY habit. He doesn't mind the occasional question and doesn't charge extra for fixing any mistakes.
With stuff that will kill you or destroy your house if done improperly, you can't cheap out.
MissKat is offline   Reply With Quote
Old 01-10-2013, 02:13 PM   #10
replacing a breaker
I'm not sure if Jim Port meant that range was too high; or too low. As said here a million times, too many factors to quote a price.
When I sold my last house, the buyer's HI noted that the P-trap under the upstairs bathroom sink was loose where it connected to the waste line. It was missing a plastic compression washer. I lived in the house for 7 years, had no idea, it never leaked, otherwise I would've fixed it. BUT the contract said any issues that we agreed to fix as a result of the HI had to be fixed by a licensed professional.
The plumber charged me $160 for what amounted to a 10 minute visit (non-emergency). Going rate in this area.....
silversport is offline   Reply With Quote
Old 01-10-2013, 02:35 PM   #11
replacing a breaker
I meant that rate was too low, and the contractor would not make enough to survive for long.
Old 01-10-2013, 05:03 PM   #12
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
replacing a breaker
Guys around here charge around 40-60 an hour. I usually charge by the job. They ask me if I can do it and I give them a rate that will allow me to make enough money. Usually more than others but they don't notice because I just say what I will do it for and it's less scary to them than 60 an hour not knowing how long it will take.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
replacing main breaker box rebelbull Electrical 8 01-18-2012 02:20 PM
Replacing two switches on one plate, each wired to a different breaker. bcainjr78 Electrical 4 10-11-2011 08:23 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
