Replacing All Receptables In Home - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 03:31 PM   #1
They are about (25) years old and too many are loose and won't hold a plug anymore, furthermore the wife wants white instead of the current ivory ones. She's hot and get's what's she wants!
There are only a couple of breakers marked now, both for the A/C the rest are undocumented. I got a quote for $30 an outlet and if it was just a few I would pay it, but I have quite a few to do.
Do professional electricians replace outlets w/o shutting down the breaker as I am thinking the price will be crazy if he has to identify the breaker, shut it down, do the work, etc? Or do they just do it?
I could do it as have done in the past and was thinking I could do it w/o killing myself in the process. I can't figure out a way to easily identify the breakers to the rooms. 3500sq, 6 bedrooms, living, etc, etc, big!
pinkfloyd43 is offline   Reply With Quote
Old 11-13-2012, 03:35 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Easy answer...turn off the main.
To label the panel, take a radio, turn it up loud, turn off breakers until you find which turns off the radio. Move on to the next one.
Keep in mind, you will need GFI's on the kitchen counter tops and tamper resistant receptacles everywhere.
Old 11-13-2012, 03:40 PM   #3
Rewards Points: 13,694
Just plug in a radio and turn it up (not a battery back up one) and start hitting the breakers.
Not worth getting hurt or burning off a wire trying to do it while it's hot.
Buy your outlets in the contractors backs and there less then $1.00 a piece and take all of 2 min. to change out.
Old 11-13-2012, 03:53 PM   #4
keeping things simple
Might be a good idea to find out if you have aluminum wiring first... not likely with a 25yr old house but you never know.
frankm1960 is offline   Reply With Quote
Old 11-13-2012, 04:10 PM   #5
Rewards Points: 150
Mapping out circuits is easy, it just takes time. But time well spent as it makes things a whole lot easier when you want to work on electrical in the future. I like to open one breaker at a time and then go investigate with my outlet tester.
I’m in the process of the switching out all of my receptacles for the exact same reasons. I recently completed the main level – 28 receptacles. I’m not as fast as Joe as it takes me on average 20 minutes per receptacle to remove old, re-strip wires, vacuum out JB, connect new receptacle, and shim so that it is snug and sits flush in the cover. No tamper-resistant receptacles here… I hate those.
silversport is offline   Reply With Quote
Old 11-13-2012, 04:17 PM   #6
Licensed electrician
Rewards Points: 1,600
The TR replacement receptacle are required if the 2011 NEC has been adopted in your area.
Old 11-13-2012, 04:39 PM   #7
Rewards Points: 254
and boy do those TR plugs suck. You will have a hell of a time plugging anything in.
I have done plugs hot but it is not fun. Shut all breakers off and changethe plugs out. Then use the radio trick or get a helper to be in a room as you start flicking breakers on and off. Keep in mind 1 breaker may do a room and a hall and another will do the fan or lights.
Also buy a non contact voltage detector - they are GREAT to have. http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
pwgsx is offline   Reply With Quote
Old 11-13-2012, 05:03 PM   #8
Rewards Points: 150
We're on 2008
Old 11-13-2012, 05:06 PM   #9
k_buz's Avatar
Still required.
Old 11-13-2012, 05:27 PM   #10
firehawkmph's Avatar
Rewards Points: 1,884
[quote=pwgsx;1051478]and boy do those TR plugs suck. You will have a hell of a time plugging anything in.
I didn't like them at first when I put them in my new shop addition. They are a little stiff to plug things into at first. Mine are all 20amp outlets. They seem to wear in after a little use. Not so bad now.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-13-2012, 05:50 PM   #11
joed's Avatar
Rewards Points: 12,852
Are the tamper proof still required when only changing the receptacle? They are not here. It is grandfathered and you can replace like for like.
The Following User Says Thank You to joed For This Useful Post:
gregzoll (11-13-2012)
Old 11-13-2012, 06:10 PM   #12
k_buz's Avatar
Required on change out.
(5) Tamper-Resistant Receptacles. Listed tamper-resistant
receptacles shall be provided where replacements are made at
receptacle outlets that are required to be tamper-resistant elsewhere
in this Code.
Think that's excessive? Here's a little food for thought...
From 2011 NEC...
(4) Arc-Fault Circuit-Interrupter Protection. Where a
receptacle outlet is supplied by a branch circuit that requires
arc-fault circuit interrupter protection as specified
elsewhere in this Code, a replacement receptacle at this
outlet shall be one of the following:
(1) A listed outlet branch circuit type arc-fault circuit interrupter
receptacle
(2) A receptacle protected by a listed outlet branch circuit
type arc-fault circuit interrupter type receptacle
(3) A receptacle protected by a listed combination type
arc-fault circuit interrupter type circuit breaker
This requirement becomes effective January 1, 2014.
This means that a simple $75 service call to replace a receptacle will now cost about $150. Now remember that not all panels have AFCI type breaker.
Old 11-13-2012, 06:18 PM   #13
That and the AFCI receptacle has not made it to the market yet either.
Old 11-13-2012, 06:37 PM   #14
Missouri Bound's Avatar
...but NEVER trust one. Use a plug in outlet tester or get a Wiggy.
Do you want it your way or the right way?
Old 11-13-2012, 07:34 PM   #15
Thanks for all the replies. Feel stupid that I didn't think of the radio thing! Glad this is here! I am by myself, wife works all day, and don't have a helper at all but with the radio I should be able to get it done!
I will do it myself and documenting the panel so I won't have to worry about it later.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 08:03 PM
replacing floor in mobile home aka trailer beech Building & Construction 2 02-23-2011 02:20 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General DIY Discussions 2 11-14-2008 07:43 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
