Replacing 240V Fuses For Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 04:36 PM   #1
Rewards Points: 49
Replacing 240V fuses for dryer
So my dryer stopped heating but still tumbles. At the 4 prong socket I'm only getting 50 or 60v. I checked all the glass fuses for continuity- I think they are fine. There is a glass fuse box with a 230v 60a black holder that pulls out, inside there were 2 40a 250v fuses. These are not blown, but do show some resistance. Is it safe to replace these with the same (or are the fuses not the problem and they can only be blown/not blown?) or should I get 30a fuses? Or should I get a gas dryer ?
Mark77 is offline   Reply With Quote
Old 01-10-2012, 04:48 PM   #2
MarginallyQualified
Rewards Points: 2,464
Does your home have a circuit breaker panel of fuses?
What is the dryer fed from?
Old 01-10-2012, 05:23 PM   #3
Electrical Contractor
kbsparky's Avatar
Those main fuses should show -0- resistance. Any other reading means you have a bad connection or blown fuses ...
-KB
Old 01-10-2012, 05:36 PM   #4
Rewards Points: 49
Hmm I think my question is going to change... It seems that the dryer is actually being fed by that circuit breaker marked D/R, which comes off the main service breaker (marked 50A). The glass fuse panel runs from that, and that black pull out thing with the cartridge fuses I was asking about must be for the oven. So I guess the D/R circuit was added after? i shut it off, and the dryer socket is dead. I turn it back on, back to about 50V. Could it or the socket or the wiring be fried?
Old 01-10-2012, 06:58 PM   #5
Rewards Points: 49
When testing the socket,
putting the probes in on each side shows about 50v.
if i put the red probe in the right side, and touch the top or bottom hole with the black I get about 125v.
if i put the red probe in the left side, and touch top or bottom hole I get 0 (or pretty close to it- its an analog meter)
Old 01-10-2012, 07:03 PM   #6
MarginallyQualified
if i put the red probe in the right side, and touch the top or bottom hole with the black I get about 125v. Good
if i put the red probe in the left side, and touch top or bottom hole I get 0 (or pretty close to it- its an analog meter)Not Good
Hot to ground (red or black) should be 125V
Hot to hot should be 240V
You appear to have lost a leg.
Going back to the fuse box... can you identify HOW that wire is being fed?
There should be TWO fuses... one for each leg.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Mark77 (01-11-2012)
Old 01-10-2012, 07:06 PM   #7
jbfan's Avatar
Rewards Points: 552
You have lost that leg.
Have you reset the breaker?
The Following User Says Thank You to jbfan For This Useful Post:
Mark77 (01-11-2012)
Old 01-10-2012, 07:07 PM   #8
Rewards Points: 49
If you look at the top picture, that breaker marked D/R below the service panel shuts off all power to the socket. I don't think the fuse box is feeding the dryer at all? or could that breaker only be 1 leg?? i didn't check each side with it off, just hot to hot.
Old 01-10-2012, 07:10 PM   #9
jbfan's Avatar
Rewards Points: 552
Since you do not have full power at the receptacle, you need to check back at the breaker.
If you are not comfortable looking in the panel, you will have to call an electrician.
Old 01-10-2012, 07:11 PM   #10
Rewards Points: 49
i reset the breaker a couple of times tonight when i was checking the socket,
and i have reset the main service breaker yesterday when I was trying to figure it out..
is there an order I should do it in?
Old 01-10-2012, 07:24 PM   #11
jbfan's Avatar
Rewards Points: 552
You have to work back from the receptacle.
This means checking the the power at the breaker.
Do you have any other 240 loads?
Are you haveing any other electrcial problems?
It is up to you to decide if you want to work in the panel.
Old 01-10-2012, 07:26 PM   #12
Rewards Points: 49
I think I found it!
I didn't realize that D/R breaker actually contained glass fuses (2x30A). It was sort of stuck shut before.
Sure enough.. 1 of them is blown.. the other shows wavering 1-2Ohm resistance so I'm off to find replacements for both.
Old 01-10-2012, 07:30 PM   #13
Rewards Points: 49
The other 240 load is our oven, which i assume runs from the cartridge fuses in the black thing in the glass fuse panel. Sometimes it does have problems getting up to full heat actually.. I'm thinking I should replace those fuses as well since they were showing some resistance..
If the dryer and oven are on at the same time, and we start the microwave, the service breaker pops.
Old 01-10-2012, 07:34 PM   #14
Rewards Points: 266
Now to find out why it blew in the first place. Some of the possiblities could be there is a problem with the dryer heating element which you will find if the fuse blows again when you go to use the dryer, but I've also seen fuses blow because the fuse wasn't making good contact with the socket contacts- poor contact causes heat that thermally melts the fuse.
If you don't mind me asking, what is in the black cabinet above the dryer fusebox?
junkcollector is offline   Reply With Quote
Old 01-10-2012, 09:06 PM   #15
Rewards Points: 49
Well I replaced the 2 fuses and it seems to be working again.. just going to do a test run now. Could the fuses have blown from age? They seemed pretty old.. And one of them wasn't exactly blown but the Ohm meter was wavering all over the place. Or possibly from multiple trips of the service breaker from having too much going at once? I'm pretty sure a dryer overload could do it which also may have happened..
Going to be very careful not to run the dryer with the oven or microwave on or much else.. I probably will look into getting a gas dryer since it is right beside the furnace anyway and the lines are right there. Don't want to upgrade our electrical system right now as we're planning major renovation (possibly building a whole new house) in the next couple years.
The black cabinet:
and its got a bunch of wires inside didnt take a pic
Need help installing new 240V oven DanDaMan Electrical 27 01-02-2012 01:12 PM
240v questions.... ITSANSS Electrical 16 05-11-2011 05:40 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Replacing 240V Wall Heater with 240V Base Board Heater jasoncw Electrical 7 11-26-2010 10:39 AM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
