Replacing A 20a Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 02:47 PM   #1
Replacing a 20a breaker
The oven in my kitchen consistently trips its breaker when using the "speed convection" setting (a cycle that uses top,bottom and rear elements, plus a fan). All other oven settings do not trip.
The existing breaker in my interior panel is a dual 10a,ganged. I checked the oven's installation manual, which mandates a 30a breaker.
Is this a case of swapping out the 2x10a for a 30amp breaker? Or do I have wiring concerns?
Assuming I juist need to swap the breaker, is this an easy task?
SixStrRzr is offline   Reply With Quote
Old 03-17-2010, 03:08 PM   #2
Master Electrician
Rewards Points: 3,966
The breaker cannot be changed to whatever you want it to be. The breaker must be sized to the size of the conductor it is protecting. Not sure how you could have a 2x10 breaker in he first place.
brric is online now   Reply With Quote
Old 03-17-2010, 03:31 PM   #3
Figured I'd need to provide more details, after I posted. I will get the model #'s of existing tonite. If I remember right, it's a double breaker "ganged" together, with a "10" on each.
It's a 10 y/o house in CA...I am assuming that this is the dedicated oven line; when the breaker trips, the oven is the only thing that goes out.
Old 03-17-2010, 04:00 PM   #4
Journeyman Wireman
Rewards Points: 150
Yeah, double check the breaker size. I've never seen a 2 pole 10 amp breaker. Maybe it's a 2 pole 40 amp with some of the writing rubbed off? See if you can determine the actual wire size and type (copper or aluminum) attached to the breaker.
Jupe Blue is offline   Reply With Quote
Old 03-30-2010, 11:02 AM   #5
OK, there are two (2) red wires going to the oven's dual breaker in the interior sub-panel. Most of the rest are black. (The Dryer circuit also has red.)
Can I assume the red wires are of sufficient size to accept 30a breakers?
Old 03-30-2010, 11:09 AM   #6
Master Electrician
You cannot asume anything. Breaker size is base on the ampacity of the wire in most cases. What size is the wire?
Old 03-30-2010, 12:17 PM   #7
Yes, a friend just told me that. I will get the wire size from the Romex jacket (10/2, 12/2. etc.) and advise.
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 10:53 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 02:44 PM
