Replacing 2-wire Cord On Old Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 07:02 PM   #1
Replacing 2-wire cord on old motor
I was given a table saw from about 1960 - actually a very good machine - it would cost a fortune nowadays, but a friend who felt he owed me one gave it to me before he moved to Florida. It has a 1 HP motor that has always worked fine and has worked fine for me in tests, but the cord is an old 2-wire version, and I want to replace it with a new cord.
The manual says to use a 10 gauge wire (the cord is about 6' long). I want to replace it with a 3-wire, grounded cord. Do I simply run the neutral wire on the new cord where the old white wire was, the black wire to where the old black wire was, and connect the ground to the chassis?
The switch is a single throw, double pole switch, by the way.
Here's a link to the manual, if that helps anyone: http://vintagemachinery.org/pubs/detail.aspx?id=2007
Arnold Ziffel is offline   Reply With Quote
Old 03-13-2012, 07:16 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Sounds good to me.
It's great to have the original manual.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
Arnold Ziffel (03-13-2012)
Old 03-13-2012, 09:46 PM   #3
that was fine , white to white which is the neutral, black to black which is the hot wire , & the green to metal chassis.
Budoy is offline   Reply With Quote
The Following User Says Thank You to Budoy For This Useful Post:
Old 03-13-2012, 10:07 PM   #4
joed's Avatar
Rewards Points: 13,354
Sounds good to me except for one thing. Put a longer cord on it so you don't need an extension cord. When I rewired mine I put a 12' cord on it.
The Following User Says Thank You to joed For This Useful Post:
Old 03-13-2012, 11:52 PM   #5
Thanks folks. Needed the confirmation. I know nothing of wiring from those 2-wire days, and had to guess that white meant neutral back then,
Replacing older lennox blower motor Jamie ivester HVAC 4 01-20-2011 06:21 PM
Replacing PSC blower motor sctb1 HVAC 5 01-06-2011 08:02 AM
Can I check my compressor before replacing? Wire was fried theedudenator HVAC 16 07-06-2010 05:27 PM
wiring an electrical motor to new cord rhollar Electrical 1 10-22-2008 10:33 AM
Replacing a Condenser Fan Motor (Goodman) guddug HVAC 8 07-03-2008 10:11 PM
