Old 06-20-2010, 03:51 PM   #1
iya
Question
Replacing 12/2 with 12/3 behind wall
Hi all. I want to replace a 12/2 running behind my wall to a 12/3.. I know it goes through one stud, but I don't know how big a hole was drilled in there. The idea of "fishing" is daunting to me, so I guess my question is, would it be possible to tape the end of the new 12/3 to the end of the old 12/2, and then pull it through, so the new one would take the old one's place?
I'm trying to do this without having to take sections of my wall out :P
iya is offline   Reply With Quote
Old 06-20-2010, 04:05 PM   #2
Licensed electrician
Generally cables are required to be secured within 8-12" of the box. When run parallel to studs no more than 4'-6" between staples.
I don't think using the old cable as a pull string will work for you.
Old 06-20-2010, 04:14 PM   #3
iya
Thanks for the quick reply, Jim Port. I guess I'll have to put more thought into this, then.
Old 06-20-2010, 05:54 PM   #4
You might be able to pull the baseboard and notch the drywall and then drill your holes.
You also might be able to go down and then back up if you have access below the floor.
Old 06-20-2010, 06:29 PM   #5
iya
Actually, this is what I'm trying to do.. The disposal unit is hardwired. It's one 12/2 straight from the switch on the wall to the upper left side of the sink, went down, then through a stud, to the right basin where the unit is attached. I want to get this set-up:
thus the replacing 12/2 with a 12/3..
I've considered just using one of those.. raceways? Like the molding things.. to cover outside-wall wiring, but I don't know how acceptable that would be in the kitchen..
Old 06-20-2010, 07:35 PM   #6
Does the switch box have the to white connected together? If so you could run a two wire cable from the switch box to the DW.
Old 06-20-2010, 08:00 PM   #7
Cables fished through walls or ceilings do not have to be fastened to studs, etc.
The old 12-2 cable installed before the drywall was put on will have been fastened to the studs and therefore could not be used as a pull string for the 12-3 cable.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 06-20-2010, 08:08 PM   #8
iya
Jim Port - Actually, yes - at the switchbox, the grounds and whites are pigtailed, while the blacks are on the switch. I suppose that IS the easiest way to do it - just wire the DW separately.
AllanJ - if I do not have to fasten to studs, do I at least have to secure them to the box itself?
Another question - The house was built in `72; could the receptacle box used then possibly not have prepunched knockout holes? I wasn't able to see any, but it could just be that it was pretty.. rusty.. in there. That's what made me think of replacing the 12/2 with 12/3 - i won't need new holes It was pretty solid-looking metal to me, so without those prepunched KOs, I'd need some good muscle to start another one for new wires.
Old 06-20-2010, 08:51 PM   #9
The knockout should be punched. You would just need to pry or push the tab out of the hole.
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Replacing Landscaping Tie Retaining Wall omnic Landscaping & Lawn Care 1 05-01-2009 06:14 PM
Replacing wall light. schnitz411 Electrical 5 04-28-2009 06:36 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
12/2 vs. 12/3 Suncrest79 Electrical 2 03-07-2009 03:42 PM
