Replacement Panel For Crouse Hinds E26095 Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2014, 12:19 PM   #1
Replacement panel for Crouse Hinds e26095 panel
It is my understanding that the almost 30 year old Crouse-Hinds panel in our mfg. home that we need to replace may be exchanged with a Siemens brand panel? I'm having trouble finding a place that sells them to DIYers, let alone anyone who knows which panels are comparable or compatible -unless I want to pay for a contractor to quote me (a phone guesstimate from one reputable local electrician was about $2K). I'd prefer to do this work myself and save some cash, but need to make sure it is the right panel. Where do I go from here?
It's a 25 am duel pole breaker for my crouse hinds e26095 panel.
Hacksaw01 is offline   Reply With Quote
Old 06-02-2014, 01:42 PM   #2
Licensed electrician
Rewards Points: 1,780
Are you saying that you are going to change the panel since you cannot find a 25 amp two pole breaker for the panel? What do you need the 2 pole breaker for?
Old 06-02-2014, 02:18 PM   #3
Rewards Points: 1,832
Why do you believe the panel needs to be replaced? If the panel has no rust, buss bar damage and is of adequate capacity it should be ok.
If a 25 amp breaker in the panel is causing you problems you can replace it with a Siemens or Murray 25 amp breaker as long as you feel comfortable doing the work yourself.
Jump-start is offline   Reply With Quote
Use panel as a junction box? LynnX Electrical 18 01-05-2014 05:56 PM
FPE Panel change out. Main Breaber to Lug TJ14u Electrical 4 01-22-2013 10:54 PM
Sub Panel over 10g-2 Help Needed hamblinh Electrical 30 01-18-2013 07:46 PM
Breaker Panel Replacement Plan jillers Electrical 24 01-28-2012 10:12 AM
Service Panel Replacement and 200A upgrade mark_anderson_u Electrical 2 09-10-2010 06:43 AM
