Replacement For A Over Cooking Range Exhaust Fan Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2013, 09:43 PM   #1
Replacement for a over cooking range exhaust fan motor
I have an old through the wall over the cooking range exhaust fan. It's motor wires insulation completely dissolved by many years of the cooking grease residue. I have an option to replace the wires or the whole motor. I don't have experience in taking apart totally enclosed motors and couldn't find a way to open it and get access to the motor insides. I tried to find suitable replacement but couldn't find similar make/model. I ordered one on Amazon and it did not fit. The old one is a following:
Universal Electric Co. Owosco, MICHIGAN
Totally Enclosed Air Over motor
SER 12Jf 75404R Mod. JA2C009G# E311P-1
115V, 60Hz, 0.66A, 1550RPM, CW, 2 prong plug
Size 3.3”x2” Single shaft 1.5”x1/4”
Two ” length mounting studs on the rear side
I will appreciate if someone with relevant experience sends me make/model of the appropriate motor. I found a cross reference tool :
http://www.centuryelectricmotor.com/...Reference.aspx
It gave me AO Smith model 20 but it does not look like my old JA2C009. I attached the picture.
Thank you in advance,
Leonid
lsyrkin is offline   Reply With Quote
Old 02-09-2013, 09:56 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What brand and model hood fan. Have you tried to contact the manufacture of the hood fan?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-09-2013, 10:02 PM   #3
It is not a hood fan but an old through the wall exhaust fan. There was a label inside but it is not readable - too old. The home is 60 years and I am not sure when the motor was installed.
BTW we are planning new kithchen and will replace all this garbage but it will be in a while. So I am reluctant to replace the whole device. $30-50 for the motor is reasonable.
Thank you,
Leonid
Old 02-09-2013, 10:05 PM   #4
rrolleston's Avatar
Thank you,
Leonid
Maybe check some appliance stores or your local electrical supply.
Old 02-09-2013, 10:13 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Go to an appliance store that has a parts counter. Not a big box or store front that sells appliance and every other thing imaginable. Go to a specialty appliance store that has a repair shop and parts counter.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-09-2013, 11:09 PM   #6
Rewards Points: 13,752
Or contact the company that made it.
http://www.uem.ca/
Old 02-09-2013, 11:26 PM   #7
Not A Licensed Pro
If you can't get an exact replacement - you could also check some HVAC supply stores for a compatible one. A couple of years ago, I went in for a new motor for my air handler and noticed they had a pretty wide range of electric motors of all sizes... maybe they can even cross reference a compatible one.
Otherwise finding a suitable one: match rotation direction (does that say CW?), shaft diameter & length, and RPM, etc... and mounting holes the same distance apart - you can transfer the mounting bolts. Bring it in hopefully they have a homeowner friendly staff... perhaps you might have better luck finding a motor meeting your specs but not the exact same model....
aside from amazon, could try http://www.surpluscenter.com/electric.asp they always have a neat oddball selection of electric and mechanical items.
kevinb70 is offline   Reply With Quote
Need help selecting replacement furnace blower motor mrnedburns HVAC 13 07-23-2015 02:04 PM
Different Capscitor for replacement motor JEOliva HVAC 8 08-21-2012 12:22 PM
Blower Motor Replacement Wiring taram HVAC 30 07-16-2012 09:04 PM
Replacement Condenser Fan Motor not working Riveree HVAC 2 06-01-2012 06:25 PM
need help with electric motor replacement kodiak_seattle HVAC 11 04-10-2011 06:39 PM
