Replacement Of Old Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 12:00 PM   #1
Replacement of old light fixture
I am trying to replace an old fluorescent light with a newer wall mounted vanity light in my kitchen. The house electrical system is still partially knob and tube. After disconnecting the old fluorescent light, I found only two cables coming from the wall (no ground). They were both black. I tested them both to find which one was the hot wire using a simple voltage tester (black pin to one of the wires in the wall, red pin to the ground in a nearby outlet), and I found that both wires seemed to be hot.
I do not expect this to be a 220V circuit (the fluorescent light I removed was a 120V fixture, and the kitchen is not on a 220V circuit breaker. The only 220 breakers are for the air conditioner and for the dryer).
Could I have made a mistake checking if the wires were hot? Should I buy a voltmeter and measure the exact voltage of the two wires? Any other suggestions?
Thank you,
Luca is offline   Reply With Quote
Old 08-15-2011, 12:15 PM   #2
Rewards Points: 6,652
What exactly are you trying to achieve, besides making sure that the circuit is dead. With Knob and Tube, I personally do not mess with it, and if anything, do not touch it with a ten foot pole. That is why I am glad that our home, when we purchased it in 2003, had BX.
Old 08-15-2011, 06:32 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,100
Do not rely solely on the simple voltage testers,
Most electricains will tell you they can give false readings.
Instead use a anologue style volt meter,
Or a good old simple test lamp,
If a lamp lights up when connectted to these two wires,
Then thats confirmation it is working.
You should consider installing an earth
if the new fitting has any metal.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Luca (08-16-2011)
Old 08-16-2011, 06:20 PM   #4
Thanks dmxtothemax!
I am about to buy a voltmeter and i will test it again,
Luca
Old 08-16-2011, 07:21 PM   #5
If you buy a volt meter,
make sure it is a anologue style type
with a low impedance input.
DO NOT BUY CHEAP DIGITAL,
as they have a high impedance input.
Which is were the problem lies.
Tags
hot wire , knob and tubing , light fixture
using light fixture to power 40" lcd tv? hoszor Electrical 3 07-21-2011 11:20 AM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 01:23 AM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 07:54 AM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
