Replacement Lighting - MR-16 Halogen For Incandescent - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 02:34 PM   #1
Question
Replacement lighting - MR-16 halogen for incandescent
Can I take an MR-16 halogen fixture and just wire it in where there was a regular incandescent light fixture, circa 1979? That's what I did and now (after roughly a year) the MR-16 won't turn on. First thing, of course was to try a new bulb.....no dice. My little cheapo outlet tester says that there is juice to the fixture and it responds appropriately with the flipping of the switch. I got a new wired socket thinking it might have been an oxidation issue, but the new one gives the same indications. Ideas?
TnseVol is offline   Reply With Quote
Old 03-18-2011, 04:21 PM   #2
Licensed electrician
Rewards Points: 1,778
A circuit needs a complete path to operate. The hot can be intact but without a way to complete the circuit the light will not work. Have you checked the white wire connections?
While there is no difference between the fixtures a lot of newer fixtures will require an insulation value higher than you have and should not be used.
Old 03-18-2011, 05:15 PM   #3
Electrical Contractor
kbsparky's Avatar
Most MR-16 bulbs operate at 12 or 24 Volts. You may have a transformer issue.
-KB
Halogen track lighting quit working Dialogdog Electrical 4 02-08-2010 09:20 PM
Dimmer for Halogen Track Lighting CompEngineer Electrical 2 12-04-2009 05:20 AM
Why use halogen lights instead of regular bulbs for outdoor lighting? darsunt Electrical 6 10-13-2009 09:58 PM
Garage Lighting Replacement burnt03 Electrical 4 10-13-2009 07:35 PM
LED vs. Halogen for outdoor lighting project philsig Electrical 3 01-09-2008 08:38 PM
