-   -   Replacement Light Fixture - Speed Wire Clip? (http://www.diychatroom.com/f18/replacement-light-fixture-speed-wire-clip-34925/)
nick4597 01-02-2009 02:19 PM
Electrical newbie here. I replaced my dining room fixture and a light fixture in my kitchen. The dining room light was easy as the wire ends were exposed for connecting into the proper white/black wire nuts.
But.... my kitchen replacement light (a small two light bulb receptacle with cover) had what the manual called "speed wire clips" attached to each end of the white and black wires. The manual states "be sure the supply circuit wires are single solid brass, stranded wires are not fit for use." The supply wires would not have fit in the small hole receptacle of the speed wire clip as there were multiple wires connected together, so I just cut the wire clips off and connected them with the wire nuts used for the old light fixture.
The light works fine, but just worried why the manual would state this. It's a standard, run of the mill 2 bulb light fixture and was basically the same type of connection and style as the one I removed, just different aesthetically. Basically looks like this:
http://www.homedepot.com/webapp/wcs/...94965801+90401
Safe? Any thoughts? THANKS IN ADVANCE
220/221 01-02-2009 02:24 PM
You're good :thumbsup:
nick4597 01-02-2009 02:36 PM
Cool.... thanks for the super-quick reply. Now on to replacing the light fixture in my bedroom with a ceiling fan :-)
jbfan 01-02-2009 04:33 PM
Make sure you have a fan rated box, or can mount the fan to a ceiling joist.
Hate to have that come down in the middle of the night!
J. V. 01-03-2009 12:49 PM
Make sure you mark the wires for your new fan install. You would not be the first to come back for help in determining what goes where.
