Replacement For GE TQL Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 10:12 AM   #1
Rewards Points: 77
Replacement for GE TQL breaker
i have a 50 year old GE panel. the new GE THQL seems to fit but the hook on side with the wire screws sticks out more then the other breakers, has a few bryant br breakers already in there that seem to fit and look ok. is there a problem with putting the new cutler hammer br breakers in there? or as long as it fits is the ge breaker ok? ge panel says to use GE R, TQ or TQL.
bryan1282 is offline   Reply With Quote
Old 10-25-2010, 06:19 PM   #2
" Euro " electrician
frenchelectrican's Avatar
To keep it simple follow the listing on the breaker box panel show what type of breaker it can be allowed to be in there.
I know some of other manufacter breakers can fit in there but you will void the UL listing easy. unless it is classifed marking on it.
Merci.
Marc
Old 10-26-2010, 09:22 AM   #3
Rewards Points: 77
i would like to do that but the breakers that are listed on the panel dont exist at lowes or home depot.
Old 10-26-2010, 10:21 AM   #4
Are you talking about this one ??
Or
This one ??
The top one is full one inch breaker while the bottom one is half inch breaker
The bottom one is only used with if you have few half inch breakers installed with side hooks but much older load centre may not able to use the half inch breaker so if you did got half inch exchange that one to full one inch single pole or full size two inch double pole breaker.
Merci.
Marc
Old 10-26-2010, 10:51 AM   #5
Rewards Points: 77
a 2 pole 30 amp is what i need, but the breaker type i need listed in the main panel is not at the store. so what am i supposed to use as a replacement? panel says GE type R, TR, or TQL, cant find those anywhere.
Old 10-26-2010, 10:58 AM   #6
Get the THQL230 breaker this one will fit. see the photo below
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
bryan1282 (10-27-2010)
Old 10-27-2010, 12:20 PM   #7
Rewards Points: 77
sounds good to me! thanks for the help!
Checking a Breaker Klawman Electrical 11 02-18-2010 07:48 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
breaker replacement maintenance Electrical 2 09-30-2004 07:28 PM
