Replacement Brushes For Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 09:10 PM   #1
replacement brushes for motor
i need help finding replacement motor brushes for a moe hoe garden tiller made by iron fireman mfg that dates back to the 50's all i can see on the brush is the number 255. the motor is a 115 v 60 hz and 1.9 amp.
ty
drwheels is offline   Reply With Quote
Old 05-12-2013, 12:47 AM   #2
JW
mm11's Avatar
Rewards Points: 592
Have you tried to find brushes at any electrical supply houses?
mm11 is offline   Reply With Quote
Old 05-12-2013, 06:52 AM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
I would call your local electric motor rebuild shop talk to them there may be some more to do than just throwing in brushes
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
J. V. (05-12-2013)
Old 05-13-2013, 09:01 AM   #4
Rewards Points: 309
Google 'carbon brushes'. Measure what you have and match it up. I use this site for a lot of mine:
http://www.graphitestore.com/cat.asp/spcat_id/3
There are many others as well.
al_smelter is offline   Reply With Quote
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
New replacement window problems iminaquagmire Windows and Doors 7 11-12-2011 12:56 AM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
motor brushes wear out fast cmacnulty Electrical 2 03-13-2011 06:32 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
