Replaceing Wall Plug And Light Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 10:42 AM   #1
replaceing wall plug and light switches
i replaced all the plugs and switches inside the house, now i have a outdoor plug that has no power. im pretty sure the 3 gang lightswitch box on in side by front door is supplying power to that plug(its above and just to the right of outdoor plug) 2 switches work and i can trace wires to lights, theres 1 switch that never powered anything(i think there used to be a lihgt in liv rm) all wires were switched 1 at a time, plugs are wired using 4 wire and supply power to switches. the red wire from 4 wire has a jumper to bottom of all 3 switches as well as what i think is outside plug, the confusing part is the black wire from 4 wire(also hot) is going into top of 3 switch. on or off the switch does nothing and does not pop breaker as i expect. has anyone ever seen this?
niondion is offline   Reply With Quote
Old 06-11-2011, 08:52 PM   #2
Electrical Contractor
kbsparky's Avatar
Betcha you have a tripped gfci unit somewhere ...
-KB
Bathroom Light & Fan Switches ryanf77 Electrical 2 04-26-2011 08:52 PM
Dimmer switches to lamps to plug in outlets keithansel Electrical 1 03-22-2011 10:53 AM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Shed: One light, one plug Crackers Electrical 2 08-31-2007 05:09 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
