Replaced Outlets, Now Wall Switches Don't Work? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 05:34 PM   #1
Question
Replaced outlets, now wall switches don't work?
We replaced two outlets with new ones so as to color match the new paint in the room. We turned off the breaker to the room, replaced both outlets and rewired them exactly like those we took out, but now none of the outlets that had previously been controlled by the room light switches are so now. We're pretty sure we wired the new outlets correctly, what would cause these plus all the other outlets to lose their connectivity to the wall switches?
PittsburghPaul is offline   Reply With Quote
Old 08-09-2009, 05:48 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Did one of the receptacles have this tab broken off and had a red on one screw and black on the other?
wirenut1110 is offline   Reply With Quote
Old 08-09-2009, 05:48 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Were they configured so one plug worked all the time and the other was controlled by the switch? There is a small tab you may need to break on the "hot" side, and make sure you use the proper hot wire on the proper screws and not just tie them all in together.
edit: Me and wirenut1110 posted at same time.
Old 08-09-2009, 05:50 PM   #4
jbfan's Avatar
Rewards Points: 490
On one or more of the receptacles you took out, the tab on the hot side was broken off.
You need to find them and break the tabs off so the switch controls the receptale/receptacles that it controled before.
3 wall outlets read "open ground" proofer Electrical 8 06-06-2009 12:02 PM
Concrete wall replaced with stick frame? jackpine Building & Construction 12 09-03-2008 04:15 PM
15A or 20A switches & outlets MIKEGOUGH1 Electrical 1 03-14-2007 07:04 PM
replaced t-stat and now my ac unit does not work ckcrew HVAC 7 12-08-2006 11:12 PM
outdoor outlets don't work. dbrew Electrical 2 12-03-2006 09:50 PM
