Replaced Outlet And Need Help. - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 09:58 PM   #61
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by 2Quik View Post
I did as you said but the outlet light switch has to be on in order outside light switch to work.
before each switch acted as it's own.
Any thoughts?
I think I know why but I think you may have one of the switch loop transported and therefore as you mention the receptale switch have to be on before you get the outside luminaire come on so check the connection at the recetaple location to confirm this part first if you do have three pairs of cables that possiblty one of them is switch loop.
If so you may want to convert one of the recetptale to unswitched and change that to convental switch arrangement ( no switch loop ) unless you have three way switches that will change the game a bit.
Merci,
Marc
Old 12-21-2012, 04:30 AM   #62
TTW
TTW's Avatar
The switch white wire with the black mark should have been the hot.
I think this is the problem.
so just swap the switch wires. here is a pic showing the ones I mean:
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
The Following User Says Thank You to TTW For This Useful Post:
2Quik (12-24-2012)
Old 12-21-2012, 05:39 AM   #63
TTW
TTW's Avatar
This is the way I was taught to install wirenuts:
Twist conductors first for a solid mechanical connection before installing the nut.
Old 12-23-2012, 08:29 AM   #64
TTW
TTW's Avatar
How did it go?
Old 12-23-2012, 12:23 PM   #65
Rewards Points: 43
Sorry i havent posted been busy with xmas stuff.
I had the same results, I have to have the the outlet switch on to turn the outside light on. Is it safe to leave it in a loop like this?
2Quik is offline   Reply With Quote
Old 12-23-2012, 12:33 PM   #66
TTW
TTW's Avatar
If you switched the wires I marked in yellow in the photo I sent, and you still have the problem, then I really don't know what to suggest.
At this point, unless I was there with a meter, I am just plain stumped.
Did you ever open the switch box at all and disturb anything there?
2Quik (10-01-2015)
Old 12-23-2012, 04:15 PM   #67
Rewards Points: 43
Its OK I can live with it.
Thank you TTW so much I apprecate very much.
