Replaced Outlet And Need Help. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 09:04 PM   #31
TTW
TTW's Avatar
Ok, please take a picture showing the silver screws (the other side)
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-18-2012, 09:14 PM   #32
Rewards Points: 43
I can't pm because i only have 13 post and i need 20 to be able to pm.
No, English is my first language.
Damn i wish i wouldn't have lost the diagram drawing i had!
so i can wire every back.
2Quik is offline   Reply With Quote
Old 12-18-2012, 09:22 PM   #33
Rewards Points: 43
Here is the other side.
If you can help me wire this back i would so grateful!!!
Old 12-18-2012, 09:25 PM   #34
TTW
TTW's Avatar
Darn too dark to see. Please try one more time.
Old 12-18-2012, 09:35 PM   #35
TTW
TTW's Avatar
OK i saw what I needed to see.
Old 12-18-2012, 09:42 PM   #36
Rewards Points: 43
ok here you go.
Old 12-18-2012, 09:45 PM   #37
TTW
TTW's Avatar
I am really tired now, been a long day. I'm going to go to bed and think about this fresh in the morning.
I think I can give you step by step instructions and have you hook up one thing at a time, checking carefully at every step, and get this figured out and back together.
Then I can tell you how to hook up the outside plug.
You will need a waterproof outside box, a GFCI receptacle, 14-2 wire, twist on wire nuts, and a weather tight cover like this.
Old 12-18-2012, 09:54 PM   #38
Rewards Points: 43
Thank you.
I have the waterproof outside box, a GFCI receptacle, 14-2 wire, twist on wire nuts, and a weather tight cover.
Thank you again.
Old 12-19-2012, 09:22 AM   #39
TTW
TTW's Avatar
OK, please do this next.
I think you said that there were 5 outlets and the outside light on this circuit. Did the outside light work? If not, is it just the lightbulb?
So, please turn the breaker off and check the outlets and find out which ones are dead and exactly how many are dead. Check both the top and bottom in each one.
Leave all the wires in that box unhooked and touching nothing and turn the breaker back on.
Check all of the outlets that were dead, and see which ones are now on. Check both the top and bottom in each one again. Also check the outside light.
Make a drawing of the room, take a picture of it, and let me know what you find out and we will go from there.
Make a drawing like this (but of your room):
Old 12-19-2012, 08:38 PM   #40
Rewards Points: 43
I checked how many outlets are effected are there are 7 outlets and one light that are affected. 4 outlets worked when i turn the barker to the on position, 3 outlets and the outside light do not.
I have attached a drawing hopefully you can see and read it if not let me know and i will try again.
Thank you so much!
Old 12-20-2012, 07:23 AM   #41
TTW
TTW's Avatar
Did the outside light work before?
Did you check both outlets, top and bottom in each one?
Which one is the one you took apart?
I was having trouble with the site here last night.
Old 12-20-2012, 08:41 AM   #42
Rewards Points: 43
Yes the outside light worked before.
Yes i check both top and bottom outlets.
The outlet i took apart was the one next to the door.
I believe the line that i have question mark on feeds power to the outside light and the recpticals that don't have power when i flip the breaker to on.
Thanks.
Old 12-20-2012, 08:48 AM   #43
TTW
TTW's Avatar
Yes, I think so too.
so next, with breaker off, connect the black wire that is hot to the black wire with the question mark with a wire nut, and connect the white to the white.
Leave the one marked switch completely disconnected.
Then turn on the breaker and see what works.
If all goes well, I'll send you a picture of exactly how to hook everything up!
Old 12-20-2012, 08:56 AM   #44
Rewards Points: 43
ok, but it will have to be this evening since i am at work.
Old 12-20-2012, 09:22 AM   #45
TTW
TTW's Avatar
No problem!
