Replaced Front Door, Help Me Fix The Alarm Sensor - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 07:49 PM   #1
Replaced front door, help me fix the alarm sensor
I replaced my front door recently and when I did of course I removed the old frame. When I removed the old frame there were two white wires for the alarm system that were in the frame, seemed like they were glued in. The door had the round magnet insert in it where the wires were in the frame. My problem is now the two wires are loose and I'm not sure if they are suppose to be soldered together or if they need to be glued in separately. When I touch the wires together the alarm beeps and if in hold them together the keypad shows the door is closed. I've tried waving the magnet that goes in the door but it doesn't do anything at all. As soon as I disconnect the wires it beeps again and says a door is open. Can anyone help me figure out how these are suppose to go back into the new door frame and how the magnet in the door triggers the alarm system telling it when the door is open and when it's closed.
Silverlx is offline   Reply With Quote
Old 02-18-2013, 08:08 PM   #2
Electrical Contractor
kbsparky's Avatar
YOU are missing the magnetic reed switch that connects to those wires.
Merely waving a magnet at loose wire ends will have no effect without the reed switch.
Here is one: http://www.ebay.com/itm/160742969254
-KB
Old 02-18-2013, 08:21 PM   #3
FANTASTIC! Thanks, anything I need to know when buying one? (Specs?)
Old 02-18-2013, 10:43 PM   #4
Missouri Bound's Avatar
You want one that is normally open, and most will be sold as NO or NC. You want the magnet to close it, like when you hold the wires together. Radio Shack will have them. If you aren't sure, ask the clerk. (and good luck with that)
Do you want it your way or the right way?
Old 02-19-2013, 11:11 AM   #5
Rewards Points: 320
I would look for an alarm supplier in your area or online. There are all kinds of contacts that you can use for doors. I prefer the plunger type for doors as there is no need to mount a magnet.
teamo is offline   Reply With Quote
Shimming toilet?? dpach Plumbing 22 05-09-2012 04:17 PM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
design tall shower front to vent okiegal Plumbing 1 01-06-2011 04:25 PM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
Physco Alarm... McGaw General DIY Discussions 13 02-15-2008 03:45 PM
