Replaced Duplex Outlet With USB/single Now Other Outlets Don't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 07:58 PM   #1
Replaced duplex outlet with USB/single now other outlets don't work
I just replaced a duplex outlet with a combo usb charging/single outlet I got at a reputable hardware store.
The duplex outlet had two white wires, two black wires, and a ground.
I used screw caps and electrical tape to secure the extra black and white wires because the new usb/outlet only had terminals for one of each.
I put it back in nicely and it works.
Then I tried to use another outlet in the room. Two duplex outlets in the room that worked previously seem to have lost juice.
What do I do with the extra wires, now? I don't have room in the box for so many more screw caps But if I did, how would I connect them so the other outlets would still work?
Please avoid lingo, and thanks!
mediaseth is offline   Reply With Quote
Old 04-14-2013, 08:00 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Why would you think that you could just cap wires you deemed unneeded and everything else will work just fine? Do you think the electrician that wired your house like running extra wires that were not needed?
You need to turn off power to that receptacle, pull it out, and pig-tail the wires to the receptacle.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
gregzoll (04-14-2013), stickboy1375 (04-14-2013)
Old 04-14-2013, 08:02 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Still cracks me up how people change the splice and then wonder why something doesn't work...
The Following User Says Thank You to stickboy1375 For This Useful Post:
brric (04-14-2013)
Old 04-14-2013, 08:04 PM   #4
Thanks for the quick reply. How do I pigtail them? I don't have extra wire, so I'm assuming I do this:
1. I get some extra wire and cut short lengths.
2. I connect the two black and an extra short length of black in a cap, and then to the outlet / repeat with white
3. done
I'll have to do it tomorrow, or run out and also buy a flashlight (I wish I was kidding).
Old 04-15-2013, 12:30 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,892
Most receptacles have provisions for daisy chaining devices. Are you sure there's no way to connect a second set of wires to the device?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 04-15-2013, 12:33 AM   #6
I'm absolutely sure. I was surprised not to find any, but they just weren't there. Everything I read on installing this usb/power receptacle combos made it seem easy. No review or article mentioned this issue.
Old 04-15-2013, 12:34 AM   #7
k_buz's Avatar
Not on those USB charging combo devices.
The Following User Says Thank You to k_buz For This Useful Post:
mpoulton (04-15-2013)
Old 04-15-2013, 12:36 AM   #8
Electrical Contractor
kbsparky's Avatar
A USB combo device is NOT "most receptacles." They only have one terminal for each circuit conductor.
Pigtailing is necessary when using such a device.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 04-15-2013, 01:05 AM   #9
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
The ones I got from pass and seymour have a screw with a plate and you can put two wires under it. Just like a GFCI.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following 2 Users Say Thank You to rrolleston For This Useful Post:
HIVOLT (04-15-2013), mpoulton (04-15-2013)
Old 04-15-2013, 03:03 PM   #10
3. done
That is correct.
OCPik4chu is offline   Reply With Quote
Tags
duplex , extra leads , outlet , single , usb
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
how to know/test if an outlet is GFI protected (water test doesn't work)? DanDaMan Electrical 17 03-07-2011 06:38 PM
Adding a duplex outlet drjay9051 Electrical 5 03-05-2011 10:15 AM
What is the problem when a number of electric outlets that do not work after I plug roger909 Electrical 2 12-12-2010 09:20 PM
outdoor outlets don't work. dbrew Electrical 2 12-03-2006 10:50 PM
