Replaced Ceiling Fixture Not Working. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 12:43 PM   #1
Braddiy's Avatar
I took down track lighting and replaced with fixture with 3 lights hanging down pendant. now new light is not working. The switch is a sliding dimmer switch it is connected to another sliding dimmer switch for another light in my kitchen. meaning both dimmer switches are connected to each other in box. as well there is 4 other sets of wires coming into box, all white wires are connected together and all black wires are connected together, there is one red wire coming into box also. I have not touched any wires at the switch or the fixture.
any ideas as to why the new fixture is not working?
I have checked and power is coming to fixture.
please help
See pictures below
replaced ceiling fixture not working.-image-3426485154.jpg   replaced ceiling fixture not working.-image-753320306.jpg   replaced ceiling fixture not working.-image-3961922580.jpg   replaced ceiling fixture not working.-image-2504088230.jpg
Braddiy is offline   Reply With Quote
Old 12-02-2012, 02:24 PM   #2
Oso954's Avatar
Rewards Points: 1,118
It may just be your photo (or my eyesight), but I don't see a white neutral wire in the ceiling box.
You need to cut the white outer sheathing off back near the clamp and hopefully find the white wire.
(what were you trying to connect the white wire from the fixture to ?)
Oso954 is online now   Reply With Quote
Old 12-02-2012, 02:31 PM   #3
Braddiy's Avatar
Confused as hell, should be simple install
There is indeed a ground white and black in ceiling box just bad picture.
I have tested with multimeter and also tested fixture in another location all working fine.
i connected fixture this way
Black to Black
White to white
Old 12-02-2012, 02:57 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 484
Bypass the dimmer and see if it works.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Braddiy (12-02-2012)
Old 12-02-2012, 08:07 PM   #5
Braddiy's Avatar
Lightbulb
Whaaalaaa
IT WAS INDEED THE DIMMER SWITCH! WHAT i dont understand is why was i getting a reading on my multimeter when i had the dimmer turned on. to the best of my knowledge i should not have been getting a reading at all.
stumped! but at least fixture works now
Thanks to jbfan CHEERS!
Old 12-02-2012, 10:00 PM   #6
SuperJETT's Avatar
Rewards Points: 156
Are they fluorescent bulbs? Some do not like dimmers as dimmers will 'chop' the AC sine wave to dim the bulb and the ballast won't even fire the bulb up.
SuperJETT is offline   Reply With Quote
Old 12-03-2012, 08:35 AM   #7
Braddiy's Avatar
Fixture working, thanks for all your replies!
The fixture was a normal 3 pendant for over a kitchen sink. bought new dimmer switch and all works fine.
but still confused about hows and whys!
cheers
Old 12-03-2012, 08:39 AM   #8
jbfan's Avatar
Rewards Points: 484
cheers
Could have been phantom voltage.
What kind of meter?
Tags
lighting circuit , lighting fixtures , lighting problem interior
Ceiling fan light no longer working? Elise Nguyen Electrical 7 09-29-2012 11:11 AM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 11:52 AM
red, white, & black wires in ceiling to white & black on new ceiling fixture ??? brand-aid Electrical 11 09-10-2010 09:12 AM
Replaced Light Fixture, additional wire? froddan Electrical 11 11-17-2009 10:55 AM
Ceiling Fixture Wiring Issue trillen88 Electrical 4 04-13-2009 06:07 PM
