Replaced Ceiling Fan Light Sockets--lights Don't Work Now - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 07:31 PM   #1
Replaced ceiling fan light sockets--lights don't work now
Had two light sockets that blew bulbs in my Casablanca Ceiling fan. I went to Lowes and purchased two ceiling lamp sockets and installed. The lights won't turn on now. Any suggestions?
momfxit is offline   Reply With Quote
Old 09-11-2010, 07:37 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the first thing to do is verify you have good lamps (bulbs). believe it or not, sometimes it is that simple.
do you have some means to test for voltage? If so, check for voltage from the shell of the socket to the contact at the bottom. (obviously make sure switch is on). Then, if nothing with that check, check from the contact at the bottom to a known good ground.
The Following User Says Thank You to nap For This Useful Post:
momfxit (09-11-2010)
Old 09-11-2010, 07:43 PM   #3
check voltage
It was as simple as putting in lamps (bulbs). Many thanks!!
Hunter Ceiling Fan & Light control #27182 slrholmes Electrical 23 03-28-2014 05:46 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
ceiling fan works, but light doesn't egildone Electrical 2 09-22-2009 11:20 AM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 08:14 AM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 12:27 PM
