Replaced Ceiling Fan With Light Fixture - Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2010, 11:44 PM   #1
replaced ceiling fan with light fixture - not working
how do I get this setup working? I've tried everything I can think of but it keeps failing.
lgoode is offline   Reply With Quote
Old 07-04-2010, 11:48 PM   #2
Just call me Andrew
Rewards Points: 1,020
Did your old ceiling fan have lights? If so, were they both turned on/off buy a single wall switch or with two switches?
What color wires do you see in the ceiling?
Andrew
secutanudu is offline   Reply With Quote
Old 07-04-2010, 11:52 PM   #3
yes, the old ceiling fan had lights. Two separate wall switches - 1. standard switch for fan 2. dimmer switch for light.
wires in the ceiling were: black, white, red, ground (copper)
Old 07-05-2010, 08:16 AM   #4
Licensed electrician
Rewards Points: 1,234
A typical setup would be black to black, red to blue or black with white stripe, white to white and all grounds together.
Have you verified power to the switches?
Old 07-05-2010, 09:17 AM   #5
Electrical Contractor
kbsparky's Avatar
Originally Posted by lgoode View Post
.... wires in the ceiling were: black, white, red, ground (copper)
Which wires did you connect to the light?
-KB
Old 07-05-2010, 10:26 AM   #6
Yes, verified power to the switches. At the fixture, I connected black to black, white to white, ground to ground. I capped off red since it was originally for the ceiling fan motor. At the wall switch, three sets of wires coming in, 1. from the circuit box: black, white & ground 2. from the light fixture: black, white, red & ground 3. from a wall AC plug: black, white & ground. At the wall switch, I twisted/connected & capped all the blacks, twisted/connected capped all the whites, twisted/connected capped all the grounds, capped off the red. When I turn on the breaker at the circuit box, the light comes on at the fixture, then when I turn off the light, it trips the breaker. Don't know what's going on - this is frustrating.
Old 07-05-2010, 10:28 AM   #7
I connected black to black, white to white, ground to ground and capped off the red.
Old 07-05-2010, 10:54 AM   #8
You should not have made any changes at the switch. Before you made changes, was there a white connected to some blacks?
Old 07-05-2010, 11:07 AM   #9
Honestly, I can't remember. I had to remove one of the wall switches anyway because last year a picture fell and broke off the on/off switch knob. Should I connect a white to the blacks? If so, the white from which wire do I connect to the blacks?
Old 07-05-2010, 02:04 PM   #10
when I turn off ? the light, it trips the breaker.
Sounds like the switch is across a hot and a neutral/ground. If so, it's probably clobbered. 400 A went through it for a few milliseconds before the breaker tripped.
If you have an incand. lamp, DVM, a 3 wire extension cord for test leads, and known good hot and ground connections somewhere close by, you can confirm what each wire does.
It's a maximum of two tests per wire, and you flip the switch for each test.
Once the grounds and neutrals are confirmed it goes pretty fast.
Old 07-06-2010, 01:50 PM   #11
My conclusion, as well. What color of wires are connected to your switch? It would not happen to be white and black?
oberkc is offline   Reply With Quote
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 01:27 PM
Ceiling fixture red wire????? meshell06 Electrical 4 10-19-2008 10:20 PM
Light switch not working! jtbel Electrical 4 12-09-2006 07:34 PM
