Replace Wire Nuts? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 09:18 AM   #1
PPBART's Avatar
Rewards Points: 295
Replace wire nuts?
Should wire nuts be replaced when removed? For example, I've removed several ceiling light fixtures to install vinyl ceiling. When those fixtures are reinstalled, should I replace the wire nuts when reconnecting the wires?
I'm asking this because my neighbor (who BTW is not an electrician) was over here yesterday to see what I was up to and he says he's sure the nuts must be replaced whenever they are removed. (Personally, it would seem to me that if the nut tightens down, it should be OK -- but I'm not an electrician, either!)
PPBART is offline   Reply With Quote
Old 10-07-2012, 09:23 AM   #2
Electrician
Rewards Points: 760
As long as they tighten down you are good to go.
darren is offline   Reply With Quote
The Following 3 Users Say Thank You to darren For This Useful Post:
electures (10-07-2012), oh'mike (10-07-2012), Speedy Petey (10-07-2012)
Old 10-07-2012, 10:49 AM   #3
Rewards Points: 1,192
I never reuse connectors.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
jbfan (10-07-2012)
Old 10-07-2012, 11:01 AM   #4
Rewards Points: 140
as long as it tightens down = what difference does it make = none.
Fix'n it is offline   Reply With Quote
Old 10-07-2012, 11:05 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 782
The only reason I have seen where they would not tigheten is if a piece of wire was stuck up inside the cone. A quick look to make sure it's clean and clear....works every time. Like Darren says....if they tighten...they are good.
The only time I don't reuse is if they are the ones that are plastic inside as well...typically the small gauge nuts....on those, after about one use, the plastic threads are pretty dull.....
But then again, I don't like useing the ones that are plasitic inside.
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 10-07-2012, 11:47 AM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Same here.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-07-2012, 12:00 PM   #7
PPBART's Avatar
Rewards Points: 295
OK, thanks to all for the prompt replies.
Old 10-07-2012, 12:28 PM   #8
But for 10 apeice,use new.
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 10:08 PM
dead wire - how to replace DIYguy2000 Electrical 0 08-12-2011 07:25 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wire Nuts Cutting Wire dw1256 Electrical 2 04-15-2010 02:12 PM
replace crimp-on connector with wire nut? Jeremy Hillary Boob, PhD Electrical 13 12-05-2008 02:51 PM
