Replace Three-Way Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 03:40 PM   #1
Rewards Points: 28
I purchased 3 new 3-way dimmable switches to replace current ones. They are made by GE and model 45614. The GE switch has a place for five separate wires while the current Leviton model only has four wires coming from the back. I called technical support at GE and the lady very rudely told me to either re-wire my switch or return them. I can't believe I am stuck with either of these two options and I assume that someone just needs to tell me how to properly wire them. I have included photos of both the old and new switch. Can someone please tell me how to wire these properly? Thank you in advance.
djwdub is offline   Reply With Quote
Old 09-26-2011, 03:42 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Where are the photos?
Old 09-26-2011, 03:59 PM   #3
jbfan's Avatar
Rewards Points: 490
The dimmer requires a neutral to operate.
Do you have a neutral wire at both switch locations?
Old 09-26-2011, 04:00 PM   #4
Rewards Points: 28
No idea. How do I find that out?
Old 09-26-2011, 04:06 PM   #5
Rewards Points: 28
If neutral wires are usually white in color I believe they are all there, they just have been all wired together and wire nutted and put behind all the switches.
Old 09-26-2011, 04:45 PM   #6
I=E/R
a7ecorsair's Avatar
Read through this:
http://forum.micasaverde.com/index.p...ic=6378.0;wap2
And these comments:
http://www.amazon.com/45614-Z-Wave-3...ews/B0035YUOWC
a7ecorsair is offline   Reply With Quote
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 01:28 PM
fitting a dimmer switch jayh Electrical 6 11-26-2010 12:40 AM
Replacing dimmer switch with regular switch? LOUSY CARPENTER Electrical 2 11-05-2010 07:21 PM
Ceiling Fan + Dimmer Switch = BUSTED brianm Electrical 3 01-31-2010 09:28 PM
Replacing dimmer switch Mike2181 Electrical 4 10-26-2009 01:12 AM
