Old 09-02-2012, 09:57 AM   #1
replace single pole light switch
I have a single pole light switch. The wires from the wall are one red, one white and one black. I attached that black wire to the green ground screw on the new switch. The new switch says "back wire clamps" next to the screws on the side of it. I attached the red and white wires to those screws.
I turned the electricity back on and the light came on, but would not turn off.
I pulled the switch out and saw that one of the wires was disconnected. I reconnected it and then the light would not come on. I switched the wires and the light still does not come on.
LindaM is offline   Reply With Quote
Old 09-02-2012, 10:10 AM   #2
Wqw! Take the old switch To where you buy parts and say I need a new switch like this. Sounds like you need a 3-way.
bobelectric is offline   Reply With Quote
Old 09-02-2012, 10:18 AM   #3
Rochsolid's Avatar
Your hot (black) wire should NEVER be hooked up to your ground (bare or green) wire. Is this light controlled by a different switch some where else? Is so you need a 3 way switch
Rochsolid is offline   Reply With Quote
Old 09-02-2012, 10:27 AM   #4
yes, there is another switch in the kitchen that controls the same light.
does that mean I need a 3 way switch?
Is the black wire always hot?
If the 3 wires are read, white and black, is there any way to know which is the ground wire?
Old 09-02-2012, 10:37 AM   #5
Ground wires are bare wires not colored.
Old 09-02-2012, 10:39 AM   #6
Rochsolid's Avatar
Black should be your "common" that will go to the black screw on your new THREE WAY SWITCH and the red and white are your travelers. But to be safe doubke check how original electrician wired up the other 3 way switch an good luck
Old 09-02-2012, 12:26 PM   #7
Thumbs up
thanks you!
I installed a 3 way switch and it works!
Old 09-02-2012, 12:30 PM   #8
Rochsolid's Avatar
Originally Posted by LindaM
thanks you!
Good job!!
Tags
light switch
Wiring a single pole wall switch to a ceiling fan and light. How ? Larry Lambert Electrical 3 03-08-2011 04:52 PM
single pole light switch bamadad33 Electrical 4 02-04-2011 09:59 PM
Single Pole Switch, but 5 wires in wall and ceiling jmo1112 Electrical 4 10-11-2010 09:51 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 12:48 PM
