Replace Recessed Lighting Baffle Trim - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 09:12 AM   #1
Rewards Points: 79
I want to remove the black baffle trim and replace it with white. It seems that it was painted over when the ceiling was painted...
Should I just pull really hard and it will come down? It seems that this should be easy, but it's stuck...
rpearlberg is offline   Reply With Quote
Old 04-03-2014, 09:15 AM   #2
I am
use a razor first around trim so you don't rip dry wall paper...
if plaster it will also help
UnclePhil is offline   Reply With Quote
The Following User Says Thank You to UnclePhil For This Useful Post:
rpearlberg (04-03-2014)
Old 04-03-2014, 09:17 AM   #3
Rewards Points: 79
Ok, after that, it should be fairly easy, right?
Old 04-03-2014, 11:36 AM   #4
Without knowing/seeing your lights we can't say for sure...but if they HALO baffles they usually attach to the cans with V-shaped wire springs on each side of the baffle. To remove the baffle, first carefully pull it down from the can to expose the V-shaped wire springs. There's one on each side of the baffle. Then press together the wire prongs of each spring to release the baffle from the can. Installation is the reverse. Good Luck.
DIYRemodeler is offline   Reply With Quote
Old 04-03-2014, 04:37 PM   #5
Rewards Points: 79
pictures added.
Replace Recessed Lighting Baffle Trim-photo-1.jpg   Replace Recessed Lighting Baffle Trim-photo-2.jpg   Replace Recessed Lighting Baffle Trim-photo-3.jpg   Replace Recessed Lighting Baffle Trim-photo-4.jpg
Old 04-03-2014, 05:05 PM   #6
That looks like a baffle with an attached reflector. The white trim ring is usually a separate piece. If you've already freed the trim ring I would clasp on both sides and pull down. This will expose the baffle. It should only drop down about 3 inches and then the wire springs I talked about above should be visible. Press each one together to unhook them from the can. When the baffle unit is free then you'll have to disengage the socket from the metal baffle assembly. Take note of which slots the socket locks into. You'll want to replace it in the same slots on the new white baffle. This is pretty easy to do but if you have never done it before please turn off the power before you do anything. Good Luck!
Old 04-03-2014, 06:58 PM   #7
Rewards Points: 79
Thanks! It looks like I need the Commercial Electric T6 Baffle, but I can only see black online...
Old 04-03-2014, 07:00 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Nope. This is not that style.
This is a Lightolier 1076/1176 (or equivalent) trim. The baffle comes out and the can is left. There are three scratch clips that hold it in place. The socket clips into the top of the can. Once the can is removed the frame-in kit is left.
Best bet is to score around the trim with a razor knife, grip the baffle and pull it down & out, then pull down on the can while slowly twisting it.
Old 04-03-2014, 07:01 PM   #9
Those will NOT fit this frame-in kit.
Old 04-03-2014, 07:04 PM   #10
Rewards Points: 79
Thank you. So after I remove the baffle, what's next? Is it easier/better to get one of those LED kits that just screw in over the existing baffle?
Old 04-03-2014, 07:06 PM   #11
Here is one option: http://www.lightolier.com/MKABrochur...s/page0321.pdf
Old 04-03-2014, 07:09 PM   #12
Here is someone with the same situation: http://ths.gardenweb.com/forums/load...044111053.html
Old 04-03-2014, 07:18 PM   #13
Rewards Points: 79
This might be more trouble than it's worth...thanks for the info.
Old 04-03-2014, 07:20 PM   #14
Rob
Robpo's Avatar
Rewards Points: 826
I would make sure the electric is off at panel if you haven't already. Sometime the hot is run to the light and coded for hot at the switch.
Robpo is offline   Reply With Quote
Old 04-03-2014, 07:25 PM   #15
Licensed electrician
Rewards Points: 1,608
not looking at dates
Removing the trim does not require accessing the wiring compartment.
brric (04-03-2014)
Best way to seal gap in drywall around recessed lighting trim TangledUp Drywall & Plaster 10 06-19-2013 07:53 AM
Recessed Lighting - Kitchen jgrohol Electrical 5 04-10-2013 11:55 PM
recessed lighting (6" Juno IC with 261w-wh wall wash trim) paul breyer Electrical 1 05-28-2011 02:42 PM
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 11:23 AM
Recessed Lighting Baffle Question CarolinaW General DIY Discussions 1 08-22-2010 07:30 PM
