Replace Receptacles And Switches.... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 08:14 AM   #1
Rewards Points: 55
Replace receptacles and switches....
How hard is it to replace electrical outlets and light switches? I want to change about 6 outlets and 2 light switches. They work, but I want to replace them with white ones....
rpearlberg is offline   Reply With Quote
Old 01-12-2012, 08:17 AM   #2
Julius793's Avatar
Pretty Easy just turn off power first
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-12-2012, 08:23 AM   #3
Licensed electrician
Rewards Points: 1,020
Remove only one wire at a time or take digital pictures. Pay attention to the screw colors, especially on a 3 way switch. Look for the broken tab on the brass side on any switched receptacles. Connect a ground to all devices including switches.
If you are trying to replace non-grounded receptacles with 3 prong receptacles there are special considerations.
Use the screws instead of the backstabs. Make a clockwise loop around the screw. Only one wire per screw.
Old 01-12-2012, 08:23 AM   #4
DIY staff
Rewards Points: 7,174
On outlets---check and see if the side tab is snapped off before you wire in the new one--save the old outlets---leave them on the floor right where you removed them until you test your work.
Often an outlet is controlled by a switch--one side switched--the other side constant power--these will have two hot wires--on the brass screws---there is a 'tab' connecting the two brass screws--
That tab can be snapped off to allow the outlet to have hot on one side--switched on the other.
Old 01-12-2012, 03:53 PM   #5
Rewards Points: 304
One thing to add.. I'd say while you're in there it also can't hurt to double check the connections, as in make sure any wire nuts aren't loose and wires are loose. I've replaced almost all of the switches/receptacles in my TH (they were painted over/etc), and some had questionable connections. If the wires feel loose in the nut (or the nut is loose), pop off the wire nut, and tighten the wires. Basically, looking at the end of the wires bunched together pointing at you, you want to make a clockwise motion twisting all the wires, which will make them tighter. Needle nose pliers work well. Then just put the wire nut back. The wires should hold themselves together very tightly w/o the wire nut. If you have a little too much extra wire (since some will be longer than others) sticking out at the end of the newly twisted bunch, just snip it off.
NewHomeDIYGuy is offline   Reply With Quote
Old 01-12-2012, 04:33 PM   #6
Rewards Points: 18
Also if your wires are silver coloured (aluminum) you will need to purchase receptacles and switches which are compatable with aluminum or you will have to pigtail with copper. How old is your house wiring?
daveb1 is offline   Reply With Quote
Old 01-12-2012, 08:33 PM   #7
Civil Engineer
Rewards Points: 4,520
Some excellent suggestions on this thread. Especially the part about taking a digital photo BEFORE you begin unwiring the box, this is especially critical if the wiring is complicated, say there are multiple switches in one box. Another suggestion is to purchase an outlet tester, you can get the for about $10 at any big box store, and check the outlets before you do any work on them. The tester will tell you if there is an open ground, reversed hot/neutral, and several other problems. You want to do this before you rewire, else you will not know if your rewiring created a problem, or it was pre-existing.
Old 01-12-2012, 09:01 PM   #8
DIY staff
This is about the most useful bunch of instructions on this common electrical task I think I've seen--
Old 01-12-2012, 11:17 PM   #9
Maybe it's worth a sticky?
Old 01-12-2012, 11:35 PM   #10
" Euro " electrician
frenchelectrican's Avatar
Oh'Mike .,
SVP do make it sticky because it will become a FAQ item.
The other thing if you have:
GFCI Repectales.,,
Please pay attetion to the line et load connection majorty of the new GFCI will not work if you get both pair or one side hook up backward.
( Et a tip along the way when you turn the GFCI on for the first time it will automatique kick out so you will have to hit the test/reset button then after that it will work fine if hooked up properly )
AFCI circuits.,
Just be extra carefull when you push the devices back in the box check to make sure you do not have any nicks on the conductors.
Merci,
Marc
Old 01-13-2012, 08:48 AM   #11
joed's Avatar
Rewards Points: 11,576
If you are going to make this a sticky please at least use the terms outlet and receptacle properly.
An outlet is any point on the circuit that can draw power(light, receptacle, fan, etc).
A receptacle is point where you plug in stuff like your TV, toaster, hairdryer etc.
The Following 2 Users Say Thank You to joed For This Useful Post:
oh'mike (01-13-2012), SD515 (01-13-2012)
Old 02-05-2012, 10:35 AM   #12
Pro
JetSwet's Avatar
Rewards Points: 502
Great point! I recently had to do this when installing 24 outlets the tabs are a trick to break, but yes, a lot of people don't realize if it has the tab to break it.
Sent from my iPhone 4 ios5
JetSwet is offline   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
oh'mike (02-05-2012)
replacing old receptacles with new decora on a 3 way light switch furniture man Electrical 3 03-06-2011 09:23 AM
Why the wide price range in receptacles and switches? Evil Scotsman Electrical 11 11-23-2010 12:43 AM
Receptacles and switches not working. Help please. Learn3r Electrical 4 09-03-2010 09:09 AM
power panel missing, all receptacles & switches removed shortsell Electrical 2 03-24-2010 11:12 AM
Blown fuses while changing switches & receptacles marc_easy Electrical 9 07-05-2009 11:24 PM
