Replace Receptacles Now Or Later? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 05:10 PM   #16
Originally Posted by DIYGST View Post
Someone had a post saying CGFI draws about a watt?
If it uses an LM1851 it draws 1.3W and an LED indicator would be another 40mW. Generally don't put a GFCI downstream of another; the troubleshooting gets weird.
Old 02-21-2009, 05:37 PM   #17
Originally Posted by chris75 View Post
Pretty strange, never had to replace every receptacle unless they were from the 50-60's era. Once in awhile you get one that gets lots of action from the vacuum and such.
I had to smash out an old slater receptacle from the late 50s and they come apart very fast. Screws holding it in were rusted and stripped.
The 30 cent receptacles are not an issue to me, I wouldn't recommend them, but they still are ok.
rgsgww is offline   Reply With Quote
Old 02-22-2009, 02:35 PM   #18
Crazy, but lovable
flyboy2610's Avatar
When we bought our house, it was through Neighborworks, Inc.'s housing purchase/rehab program. The inspector from Neighborworks wanted us to put a GFCI behind the refrigerator. The electrician whom our contractor subcontracted said "Uh, uh! Ain't no way!"
Putting a GFCI behind the refrigerator can lead to an expensive mess. He said if you get a power surge while you're on vacation, it could trip the GFCI. Then when you get home, everything in the refrigerator is ruined.
flyboy2610 is offline   Reply With Quote
Old 02-22-2009, 02:40 PM   #19
Rewards Points: 278
Can I put a regular 20 AMP receptacle behind the refigerator? (It's on a 20 amp circuit, but not dedicated for this outlet though)
the 20 Amp has good plug retention, which is why I want to use it, no other reason..
DIYGST is offline   Reply With Quote
Old 02-22-2009, 03:04 PM   #20
Electrician
Why would you leave food in your fridge if your going on vacation?
chris75 is offline   Reply With Quote
Old 02-22-2009, 03:04 PM   #21
If its on a 20a circuit then Yes
Old 02-22-2009, 03:07 PM   #22
How would the average household not leave food in their fridge?
With everything we (wife) buy its not really possible to empty a fridge for a weeks vacation
Old 02-22-2009, 03:12 PM   #23
Electrician
I understand that, but you wouldnt fill it up before you left either... Seems you would have minimul food in it just in case the fridge stopped working for any reason, not just GFCI protection.
Kind of my point actully, just dont understand the relationship behind not installing a GFCI on a fridge when so many other factors play in, such as loss of Utility power, and the appliance breaking. In other words, who cares if the fridge is GFCI protected or not.
Old 02-22-2009, 03:20 PM   #24
Not me, as long as the fridge shell is grounded, either from the factory or by the HO.
Old 02-22-2009, 03:36 PM   #25
I've tried to convince the wife that the grocery store will be open every day. She's not listening I've never in my life frozen potato chips, but she always has some in the freezer. I guess they do take up air space, so its that much less cold air that escapes when the door is opened. Same with CVS/drugstores, she buys stuff when we don't need it. Then by the time we do need it it's almost expired
I've never had a GFCI protected fridge or freezer
Is the fridge/freezer shell grounded by the cord at the factory??
So if you only had a 2 prong outlet a GFCI would be a good idea?
Old 02-22-2009, 04:16 PM   #26
Electrician
That was hilarious!
GFCI protection is becoming more and more common in residential settings, codes keep changing, I'll i'm saying is that there is nothing wrong with them on GFCI's... They are required in all commerical kitchens for a reason. safety!
Old 02-22-2009, 07:20 PM   #27
I'd run my own ground wire first unless there is nothing grounded in the vicinity. Then you couldn't touch the fridge and a ground at the same time.
Old 02-22-2009, 07:39 PM   #28
I was thinking more of some houses that have all the old 2 prong outlets. I know many people just install a new 3 prong outlet & think all is good
Old 02-22-2009, 07:43 PM   #29
Electrician
That would be a code violation to install a GFCI receptacle in place of a two wire receptacle suppling a fridge or a freezer.
Old 02-22-2009, 07:51 PM   #30
Where is this in the nec? I would like to read it.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 01:21 PM
