Replace Pressure Switch , Someone Else Took Off. 4 Wires From Box. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 08:32 PM   #1
replace pressure switch , someone else took off. 4 wires from box.
4 wires from box 2 black 1 white 1 copper. 2 white wires come from pump. Where do they go on 30-50 well pressure switch?
karkar is offline   Reply With Quote
Old 05-30-2012, 08:38 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
A wiring diagram exist under the cover of the pressure switch.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 05-30-2012, 08:43 PM   #3
dSilanskas's Avatar
is the breaker a single pole or 2 pole?
dSilanskas is offline   Reply With Quote
Old 05-30-2012, 08:43 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Colors mean nothing. You'll have to take a pic and post it.
Old 05-30-2012, 08:59 PM   #5
at power box 2 poles both say 20
only tells volts, 1 P N etc.
Old 05-30-2012, 09:04 PM   #6
Missouri Bound's Avatar
From your questions, and half answers you may want to call someone qualified to do this for you.....in my opinion.
Do you want it your way or the right way?
Old 05-30-2012, 09:04 PM   #7
joed's Avatar
Rewards Points: 11,614
The power feed feed goes to L1 and L2. The motor wires go to T1 and T2. The bare and green are grounds and go to the metal frame of the switch.
Old 05-30-2012, 09:26 PM   #8
2poles in power box each have 20 on them
Old 05-30-2012, 09:32 PM   #9
that would only be 5 wires, where does the white 1 from elec outlet box go?
Old 05-30-2012, 09:38 PM   #10
don't think i'm that savvy w/getting pic onto here. motor 2 w/wires into pressure switch then an outlet box w/ 2 plugins then wires goto power box , 2 poles w/#20 on each.
Old 05-30-2012, 09:42 PM   #11
Not this one
Old 05-30-2012, 09:46 PM   #12
2 pole both have 20 on them.
Old 05-30-2012, 10:20 PM   #13
Rewards Points: 582
wires from panel box is line ....wires to pump motor is load...its 220volt...
Old 05-30-2012, 11:03 PM   #14
OK but there are 4 wires coming from panel box(power) I think 2 from motor go to 2 middle screws and atleast 2 wires go to the outter screws and the copper goes to ground (green) screw but still 1 more wire from power box gon't know where to put!
Old 05-31-2012, 07:03 AM   #15
E2 Electrician
Im not going to assume anything until I see a picture.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Any electricians? Question about a DC switch. Switch is on ground wire(s). Deck Electrical 22 01-14-2012 05:21 PM
Open pressure switch on furnace Dale0202 HVAC 4 01-26-2011 11:35 PM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 07:41 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
