-   -   Replace old dryer recepticle (http://www.diychatroom.com/f18/replace-old-dryer-recepticle-1737/)
Christo 01-26-2006 05:04 PM
I have an old 250-V dryer recepticle with 3 slots. I bought a used Kenmore dryer that has a 4-prong plug. The wire in the house is a 1958 vintage, 3-wire cable coming from a 30 AMP breaker. The conduit is mounted on a cynder block basement wall, but there's no ground cable. Can I replace the 3 slot recepticle with a 4 slot recepticle?
thanks
joed 01-26-2006 07:07 PM
If the conduit is continuous it should be acceptable as a ground or you could pull in a ground wire. You could also convert the dryer to a three prong plug.
