Replace Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 07:18 AM   #1
replace light switch
The light in my kitchen won't come on properly when we flip the switch. We have the old long flourescents outlet and when we flip the switch we often have to keep flipping it up and down to get it to come on. Some times it will come on partially and you have to paly with the switch to get it to come on full power. At times when you flip it you can hear a hum at the outlet but the light is not on. 1. Is this most likely a bad switch or something in the outlet? 2. Do I really need a voltage tester to change the switch? Help.
Veltorio is offline   Reply With Quote
Old 02-04-2014, 07:37 AM   #2
joed's Avatar
Rewards Points: 12,860
Most likely bad tubes or ballast in the fixture.
The Following User Says Thank You to joed For This Useful Post:
gregzoll (02-04-2014)
Old 02-04-2014, 07:38 AM   #3
Rewards Points: 13,712
Or even just a loose bulb.
Old 02-04-2014, 08:29 AM   #4
Rewards Points: 6,652
Bad tombstones, bad ballast is the two first culprits to look at. If the fixture is really old, I would just get new Tombstones & ballast, bulbs, and go from there. You do have a good DMM (Digital Multi-Meter), so you can check the wiring resistance for any problems, along with when you put everything back together.
The bad thing about Kitchens, is if you do a lot of frying, that grease will eat any plastic it touches, along with gumming up electrical contacts.
Fan and Light Operate Erratically after install of another switch next to it CHEMTRAILS Electrical 12 10-15-2013 08:25 AM
Trying to replace electric mower switch with normal light switch orrgroup Electrical 6 06-12-2012 05:45 PM
Replace Light Switch NewOwner23 Electrical 1 12-13-2011 06:58 PM
Replace light switch justinae Electrical 27 06-16-2011 05:31 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
