Replace Double Taps With Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 06:41 PM   #1
Replace double taps with junction box
As a continuation of my other thread I need to fix my two double tapped breakers.
Breaker #1 - Panel plug + outdoor lamp post
Breaker #2 -Refrigerator + door bell
I'm thinking the simplest/best thing to do is to but a junction box next to the breaker panel and do the following:
Breaker #1 - Junction box connecting panel plug + outdoor lamp post + door bell
Thoughts and suggestions are welcome
inkognito is offline   Reply With Quote
Old 09-19-2011, 06:45 PM   #2
Code05's Avatar
Rewards Points: 1,104
Splice in panel. Junction box is not necessary.
Code05 is offline   Reply With Quote
Old 09-19-2011, 06:52 PM   #3
Forgot to clarify that I'm located in Canada and I'm not sure whether that's allowed by code here. Maybe others can verify.
Old 09-19-2011, 07:06 PM   #4
Code05's Avatar
Yeah, CEC may be different.
Old 09-19-2011, 07:47 PM   #5
Licensed electrician
Rewards Points: 1,616
I believe splice are prohibited in a panel under the CEC.
What brand breakers do you have? Some are listed by UL in the US to accept two conductors.
Old 09-19-2011, 09:17 PM   #6
My breakers are definitely not rated for two conductors.
I did some more research and found that you cannot splice inside the panel other than to extend a wire - in cases where you e.g. replace the panel and some of the wires are too short to reach to a breaker.
The doorbell transformer is attached to the panel too which means I have to detach it so I can run the 14/2 into the JB (or the panel plug I suppose).
Split 220v in a junction box into 2x 110v dsoelter Electrical 10 07-10-2010 09:25 PM
double walled ductwork question(s) peyton HVAC 8 04-19-2010 10:02 AM
Two Breakers for 1 Double Recepticle Box? mfleming Electrical 9 03-10-2010 07:28 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
