Old 05-22-2012, 01:56 PM   #1
Replace dimmer switch with normal switch
The switch bow has a red and a black wire
kharker is offline   Reply With Quote
Old 05-22-2012, 02:39 PM   #2
kevinp22's Avatar
bow? or
seriously, the dimmer probably has 2 blacks and a green or a black a red and a green (assuming it isnt a 3 way switch)
take the wire connected to the green and connect to the grounding screw on the new non dimmer switch. take the 2 wires connected to the black and/or red on the dimmer and connect them to the 2 terminals on the switch.
If there is a bundle of white wires in the box leave them alone. If there is only a black wire and white wire coming in (not including ground) make sure the white wire is identified as a hot by adding black tape around it.
if its a 3 way switch let us know as it is a bit more complicated
kevinp22 is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
replacing a dimmer switch with regular switch demus72 Electrical 2 11-10-2011 02:54 PM
2 way dimmer & 3 way switch paulegan25 Electrical 14 11-22-2010 01:37 PM
Replacing dimmer switch with regular switch? LOUSY CARPENTER Electrical 2 11-05-2010 08:21 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
