Replace Canned Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 12:47 PM   #1
replace canned light
how to replace canned light with regular fixture
2repa1rit is offline   Reply With Quote
Old 10-13-2011, 01:29 PM   #2
Licensed electrician
Rewards Points: 1,054
Most likely you will need to remove the recessed housing and install a new work box attached to the framing and then patch the hole. You may need to install framing if the recessed was between the framing and not alongside it.
There are also surface mount trims for recessed lights that might suit your needs.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
How much and how difficult to replace a kitchen light ballast? Godzealot Electrical 5 02-02-2011 08:17 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Reasonable cost to replace mailbox and light post? akphs Off Topic 1 04-26-2010 10:55 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
