Replace Breakers With "arc Fault Protected" Ones? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 09:44 AM   #16
Rewards Points: 2,350
As far as the OP... that is a pointless waste of money. Not only are AFCIs junk, but you will have to virtually disassemble your panel to put them in. Your receptacles probably weren't melted due to an arc. Likely they were melted by high contact resistance. Your best bet is to just swap the outlets out. Far cheaper.
Old 05-05-2009, 10:12 AM   #17
Rewards Points: 3,130
Originally Posted by Scuba_Dave View Post
Not lots of locations according to this
http://www.childoutletsafety.org/fil...doptionMap.pdf
Apparently not as many as I thought. But WV still hasn't adopted it according to their official website. And no place I know of around here even carries TR receptacles.
Old 05-05-2009, 10:40 AM   #18
31b
sparky
not sure about other states, but here it varies from township to township too.
31b is offline   Reply With Quote
Old 05-05-2009, 10:50 AM   #19
That's what I'm slowly doing. Out of about 15 replaced so far, about 4 looked partially "melted". The ones I'm replacing are all cheap builder-grade, which don't hold anything plugged-in very tightly. All were installed with the "stab in the back" quick-connects.
Doesn't sound like AFCIs are quite ready for "prime-time"...
bassman99 is offline   Reply With Quote
Old 05-05-2009, 12:31 PM   #20
"Once we have AFCI on all of the circuits and there are still fires of electrical origin, there should be a very large class action product liability suit that will remove the product from the market and punish the shareholders."
Old 05-05-2009, 01:35 PM   #21
Wink
arc fault circuit breakers:
I agree with your contention that the AFC breaker didn't detect the arc fault and didn't trip. The early editions could only detect "across-the-line" faults and were useless in "series" (line-to-line or neutral-to-neutral) faults. When I inquired @ the electrical supply store, whether they detect series faults, and couldn't get a firm answer, I knew how much they were worth. However, the newer, Combination AFC is effective on all kinds of arc-faults. One note of caution, however! If there is any (intentionally or otherwise) grounded neutral, on the circuit the [comb.] breaker will trip as soon as it's energized!!!
There are methods to find and eliminate the "grounded neutral" from the line!
spark plug is offline   Reply With Quote
Arc Fault breakers (warning) Potomac101 Electrical 68 01-05-2012 03:22 PM
arc fault breakers handifoot Electrical 44 01-31-2009 05:10 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 10:19 PM
ARC Fault Breakers tripping after a fan install. jAutumna Electrical 32 03-20-2008 08:10 AM
