Replace Breakers With "arc Fault Protected" Ones? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2009, 03:21 PM   #1
Replace breakers with "arc fault protected" ones?
I have a main panel with circuit-breakers in the US, circa 1994. I've recently heard about "arc fault protected" breakers, and was wondering if they come in "standard sizes" so the typical homeowner can upgrade (perhaps via an electrician), simply plugging-in the new ones.
I've found some outlets in my house that were partially melted due to the builder using the "quick connect" feature on cheap outlets/switches, coupled with heavy draw (space-heater, vacuum cleaner, etc.). I'm slowly replacing the outlets (without the "quick connect"), but in theory, arcing could still occur.
Curious...
bassman99 is offline   Reply With Quote
Old 05-03-2009, 03:37 PM   #2
I think this is primarily due to high contact impedance + heavy current, and not due to arcing.
You should be able to hear arcing on the AM band, between stations.
http://www.google.com/search?hl=en&s...22&btnG=Search
Old 05-03-2009, 04:46 PM   #3
Idiot Emeritus
Rewards Points: 1,492
Arc-fault breakers are a RED-HOT topic of contention among electricians, inspectors, building departments, code-making persons, etc.
Here's my personal opinion. They're one step worse than worthless. Here's why.
When they first became required, I was a bit skeptical of their ability to 'detect the characteristics of an electrical arc'. The only thing I knew of that can actually detect an electrical arc is a line protection relay that the power company uses on their transmission and distribution lines. Not only can it detect an arc, it can tell you how far away the arc occurred. It costs about $3500.
I decided to conduct an experiment. I hooked up an arc-fault breaker in a panel, and brought the two wires out to a test bench. I wired a cord cap on the end of the wires. Next, I cut the end off of a cheap two wire household extension cord. I then stripped about 4" of insulation off the end of the cord, so that all the fine strands of wire splayed out. Next, I plugged the cord into the cord cap that was connected to the arc-fault breaker.
Lots or arcs, lots of sparks, but the breaker didn't trip. I shook the end of the cord around. Even more arcs and sparks, but still no trip. Next, I shoved the bare ends of the cord onto a steel table top. That tripped the breaker. (Don't try this at home kids, I had insulating gloves on as well as other protective gear, plus 19 years of electrical experience.)
My conclusion is that the arc-fault breaker failed to detect the characteristics of an actual electrical arc that certainly would have caused a fire, had it been near anything combustible. The fact that it tripped when directly shorted seemed to indicate that it wasn't defective.
The reason my opinion is that they're less than worthless is based on the false sense of security one might have if these are installed. Frayed cord...no problem...I've got arc-fault breakers. Impossible to start anything on fire.
They might be improved by now, but when they first came out they were nothing more than a breaker with a magnetic trip unit set at about 75 amps (as opposed to about 150 for a normal breaker), and a 30 milliamp ground fault trip unit. One of the biggest complaints I hear about them is a basic vacuum cleaner will trip them. The starting surge of a 12 amp vacuum is about 100 amps.
All code-making committees have at least one manufacturers representative on them. The original purpose was to be sure that something they were thinking of requiring could in fact, be made. In the case of arc-fault breakers, it was the manufacturers that pushed the requirement the hardest. Hmmm......
Rob
micromind is offline   Reply With Quote
Old 05-03-2009, 04:54 PM   #4
Yup, some vacuums & other devices will cause them to kick off
I'm not sure on the added value/protection either
But they are required now here, and almost everywhere else
Old 05-03-2009, 05:52 PM   #5
"Abstract:
Provided is an arc wave generator for testing an arc fault circuit interrupter (AFCI) for use in a test system for testing whether or not an arc fault circuit interrupter (AFCI) is operating normally, in which a false arc is generated for use in testing the arc fault circuit interrupter (AFCI)."
But, is their "calibrated arc" traceable to NIST?
Old 05-03-2009, 06:18 PM   #6
Bigplanz's Avatar
Rewards Points: 990
It will be interesting to see some reports from the field on nuisance tripping on AFCI breakers now that the are required on virtually every 120V circuit in residential construction.
Bigplanz is offline   Reply With Quote
Old 05-04-2009, 08:10 AM   #7
Rewards Points: 3,130
I thought AFCIs were only required for bedroom outlets, and then only since NEC 2008. Lots of locations, mine included, still use NEC 2005.
Old 05-04-2009, 08:28 AM   #8
electrician
Well, if your area uses the 2005 then it is required in bedrooms. 2008 required it in more places.
Silk is offline   Reply With Quote
Old 05-04-2009, 09:46 AM   #9
Not lots of locations according to this
http://www.childoutletsafety.org/fil...doptionMap.pdf
Old 05-04-2009, 06:39 PM   #10
Bigplanz's Avatar
Rewards Points: 990
The differences between the 2005 and 2008 NEC can best be found here.
http://www.ecmag.com/index.cfm?fa=ar...articleID=7820
Old 05-04-2009, 06:52 PM   #11
Over the years, is the NEC converging onto some final copy or does it continue to add substantial changes? Is it getting thicker?
Just curious.
Old 05-04-2009, 06:57 PM   #12
Changes occur as technology develops to prevent problems
IE GFCI & AFCI breakers
As better ways are "discovered" to wire or avoid problems new code is introduced or old code changed
And as Mfg see an opportunity to make more $$ selling something new
Who knows what the future holds?
Old 05-04-2009, 06:58 PM   #13
Bigplanz's Avatar
Rewards Points: 990
Just curious.
2005= 772 pages
2008= 822 pages
Old 05-04-2009, 08:23 PM   #14
2005= 772 pages
2008= 822 pages
+2% per year. Not bad.
Old 05-04-2009, 08:29 PM   #15
Try the handbook - over 1300 pages
But sometimes a picture is worth a thousand words
Arc Fault breakers (warning) Potomac101 Electrical 68 01-05-2012 03:22 PM
arc fault breakers handifoot Electrical 44 01-31-2009 05:10 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 10:19 PM
ARC Fault Breakers tripping after a fan install. jAutumna Electrical 32 03-20-2008 08:10 AM
