Replace A 3 Wire With A 3 Wire Toggle Switsh - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 03:53 PM   #1
Replace a 3 wire with a 3 wire toggle switsh
I need to replace a three wire dimmer with a three wire toggle switch
Handy4 is offline   Reply With Quote
Old 11-23-2011, 04:20 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Find the common wire, make sure you connect it to the common screw, then put on the other two wires.
jbfan is online now   Reply With Quote
Old 11-23-2011, 06:46 PM   #3
Thank you but how do I identify the common wire? The existing dimmer has one black connected to a white and two reds one to a red and one to a black.
Old 11-24-2011, 07:46 AM   #4
Rewards Points: 1,548
Because of the wide variety of ways in which 3 way switches are wired up, you will need to describe all of the wires and how they are grouped (the various cables) and how they used to be wired up, in both the dimmer switch location (box) and the remote switch location (box).
In some 3 way dimmer setups the wires are not called common and traveler but instead are called hot, neutral, and control.
Old 11-24-2011, 12:36 PM   #5
joed's Avatar
Rewards Points: 13,728
The odd colour wire on the dimmer will be the common. In your case the one black is the common and the two reds are the travellers. So put the white wire on the common(black) screw and the red and black on the other two screws.
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 12:51 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 01:23 PM
