Replace 3 Prong Dryer Receptical With 4 Prong - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 07:05 AM   #1
Rewards Points: 280
replace 3 prong dryer receptical with 4 prong
I have a 25 year old house with 3 prong 30 amp dryer receptical. I have a newer electrical dryer with a 4 prong 30 amp plug. The existing box has 4 10 ga wires black, white, red and bare ground.
It seemed like the easy, best, cheapest thing to do was replace the receptical/outlet with a 4 prong dryer outlet. They must have went to 4 prong for a reason right? I am not an electrical engineer, but I think I can change out an outlet, without burning the house down.
I go buy a matching 4 prong dryer outlet, wire it up and it will not fit into the existing new construction type wall box? The existing wall box is a standard brown plastic approximately 2X3 1/2 nailed to the studs and drywalled over type box.
The receptacle will not fit in the box, it is bigger than the original 3 prong receptacle! So now what is the easiest, cheapest, best way to solve my issue?
JIm
jjrbus is offline   Reply With Quote
Old 01-28-2013, 07:35 AM   #2
Rewards Points: 6,652
You already have a 4-wire hook-up, just need to get the proper dryer outlet & cord, then connect the cord, and remember to remove the bonding strap or jumper from the White/Neutral inside the dryer.
As for the "box" really need a picture to see what you are talking about. If the outlet is incorrect, most likely whomever installed it, may have used a Range outlet, not a dryer outlet.
Old 01-28-2013, 11:13 AM   #3
Extension
I had this issue. The new dryers have a four-prong plug with a separated ground. You can add a new square extension box on top of the existing box in the wall in order to fit the new receptacle. The new box will stick out from the wall.
Moritasgus is offline   Reply With Quote
Old 01-28-2013, 11:23 AM   #4
Here is a picture of my dryer receptacle. This is just a standard square box (check the setup at the hardware store to make sure everything fits). Then feed the wiring through the new box and attach it to the old box. Ground the new box.
Old 01-28-2013, 11:23 AM   #5
Rewards Points: 14,306
It's a nutral not an added ground.
Need one like this.
http://www.bing.com/images/search?q=...lectedIndex=55
If you have a shallow box it still may not fit and the box will need to be changed.
Old 01-31-2013, 12:35 PM   #6
Rewards Points: 280
Thanks for the responses! I was able to carefully remove the existing 1 gang box and replace it with a new 2 gang old work box.
What should have been a simple litlle job takes hours! JIm
Old 01-31-2013, 06:19 PM   #7
Rewards Points: 266
Make sure all the conductors are hooked to something and to the right something. I've been tempted to make such assumptions before and been glad that I did not.
ionized is offline   Reply With Quote
Old 01-31-2013, 08:34 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,990
Need one like this.
It is an added ground. The old ones have two hots and a neutral, and are ungrounded. The prior code allowed the chassis of the dryer to be bonded to the neutral for some measure of safety. That is no longer allowed, so a separate grounding conductor is required. This is an important distinction because sometimes people think that 10/2 cable used to be allowed for this application. It never was - it doesn't have an insulated neutral conductor. The neutral has always been required to be insulated, but used to be allowed to double as a bonding conductor.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
open neutral on dryer...dryer won't work inspectorman Electrical 32 02-20-2012 02:16 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Gas Dryer - Install Flex Line and Also No Heat mark2741 Appliances 8 07-05-2011 12:10 AM
dryer receptical berg76 Electrical 4 10-23-2010 06:19 AM
Replace old dryer recepticle Christo Electrical 1 01-26-2006 06:07 PM
