Repairing Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 01:09 AM   #1
Rewards Points: 225
repairing wire
Have a 14/2 wire with a slight abrasion on it. The wire is exposed to the cold. Wire is somewhat old. What to use to repair it? Tape or ? Thanks.
gt1935 is offline   Reply With Quote
Old 07-26-2013, 04:43 AM   #2
dmxtothemax's Avatar
Rewards Points: 5,096
Please elaborate on "slight abrasion"
What exactily is damaged ?
And how badly ?
Is the primary insulation damaged or only the secondary ?
Is the metal exposed in any way ?
Safest route is to replace the cable section.
But thats not always easy is it ?
dmxtothemax is offline   Reply With Quote
Old 07-26-2013, 09:08 AM   #3
Rewards Points: 6,652
What do you mean exposed to the cold. Is this wire up in the Arctic circle, or Antarctica?
If the wire has enough jacket covering worn off, that it is showing the copper, you need to cut it and if enough slack, install a Junction box, or use the Wago connectors that can be used without a junction box, for the repair.
Old 07-26-2013, 09:10 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Where is the cable located? Be specific. Is it in a wet location? Can you post a pic?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-26-2013, 09:54 AM   #5
Rewards Points: 225
wiring
Old 07-26-2013, 12:12 PM   #6
Licensed electrician
Rewards Points: 1,018
Could someone provide a link to these connectors that do not need a box?
MTN REMODEL LLC (08-03-2013)
Old 07-26-2013, 12:58 PM   #7
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
http://www.amazon.com/home-improvement/dp/B0035LKG6Y
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 07-26-2013, 04:45 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Those are not Wago's and definitely can not be used in a wet location. And some AHJ's probably will not allow anywhere.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Jim Port (07-26-2013), MTN REMODEL LLC (08-03-2013)
Old 07-26-2013, 06:14 PM   #10
Wago , Tyco, Hugo, whatever.
Old 07-26-2013, 06:59 PM   #11
electures's Avatar
wiring
Huh? Do you want help or not?
Old 07-26-2013, 09:45 PM   #12
You do realize that the term Wago has become as common as Shark Bite for a product that may not be made by the company, but serves the same type of purpose. It is like stating that you want a Coke, but grab a Pepsi. All depends on where you live.
As for AHJ's, yes it is ultimately up to them to decide, that is why no one says that it is fine to use them, but it is an option to use if you can.
Old 07-26-2013, 10:15 PM   #13
Since we all live in different areas it would help if the correct verbiage was used. It would also help someone searching for a specific product instead of wasting time on the wrong site.
electures (08-03-2013)
Old 07-27-2013, 06:42 AM   #14
Rewards Points: 516
about 2 years ago we were introduced to the type of connector ...
call several inspectors and yes it could be used as a splice behind the drywall buried ..
I am not a big fan but there have been a few uses for it..
this is the brand that we use.
CES sells them .. City Electric... along with other top supply houses
NSI is the Brand ..here is the cut sheet ...
The Following User Says Thank You to Philly Master For This Useful Post:
gregzoll (07-27-2013)
Old 07-27-2013, 06:58 AM   #15
An old Tradesmen
Rewards Points: 6,088
Philly. I think you posted the wrong PDF.
The Following User Says Thank You to beenthere For This Useful Post:
Philly Master (07-27-2013)
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
