Old 02-07-2009, 12:23 PM   #1
repairing dual rocker switch
part: 125V dual rocker lit snap in O/F switch
for: oil radiator heater/fan
Right off noticed the heater rocker was loose (even its 'on' light flickered) in sharp contrast to the tight clicking tension on the fan (don't use) side. As is, it worked for many months ... now DOA, I think that rocker is the sole problem & believe it's repairable, but have several Qs:
1)Despite being seemingly soldered on, the 6 rear connectors must be 'plugs' I can gingerly disconnect (how else to replace), right?
2)Since the fan rocker's fine, can I either:
A)simply reverse each rocker's 3 wires to use the fan side for the heater?
B)less simply (can't figure out if I CAN separate ext lid from int casing in order to access rockers--any hints here?) switch out the good for the bad?
...if not...
C)(given access) maybe repair what's likely a detached spring on the dead rocker?
I suspect a single spring is the difference between this good heater being salvaged or scrapped...any been-there-done-that DIYer ideas?
jackofnone is offline   Reply With Quote
Old 02-07-2009, 01:23 PM   #2
Unplug it when you work on it and stand clear when you plug it back in.
220/221 is offline   Reply With Quote
Old 02-07-2009, 03:30 PM   #3
Or spend $7.00 for a new switch?
Gary
Gary_602z is offline   Reply With Quote
Old 02-07-2009, 07:08 PM   #4
Check Radio Shack. They seem to have a decent selection of lighted switches. Be sure the current rating is same or higher than the old one.
FW
KE2KB is offline   Reply With Quote
Old 02-08-2009, 10:49 AM   #5
Question
Before posting I already tried to find a replacement–only to discover the universal dual-rocker model won't fit. Considered including the odd shape/size of this switch–figured I'd get some JUST BUY A NEW ONE replies for not mentioning that fact, but hoped I'd also get answers to my questions, all I really need to know is:
CAN I SWITCH (REVERSE) THE IN, OUT & GROUND WIRES ON THE BAD SIDE WITH THE IN, OUT & GROUND ON THE WORKING SIDE?
Old 02-08-2009, 11:54 AM   #6
J. V.'s Avatar
Replace the switch. Be safe and smart.
Leviton Lighted 3-way Rocker. Switch works but does not illuminate J187 Electrical 16 01-04-2009 01:21 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 03:39 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
replaced 3way toggle with rocker switch - what's wrong? ellabo Electrical 8 09-22-2008 05:16 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
