Repairing A Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 11:04 PM   #1
Repairing a Chandelier
I took home a used chandelier and didn't notice until I got it home that a couple of the candelabra holders are loose. How to I get to these to tighten them? There is a light on the bottom of the candelabras. Also, one of the white sleeves that holds one of the candle lights is burnt. How would I go about checking the wiring on this particular receptacle to make sure it is okay. How do I detach the bottom light to get to the candelabras(if that's what they are called). I got it for free so there are no directions with it. Any suggestions would be greatly appreciated. I really can't afford an electrician and the is my DIY project.
Thank you in advance.
vtcarol50 is offline   Reply With Quote
Old 09-12-2010, 11:13 PM   #2
Rewards Points: 558
Please supply pictures so we can try and walk you through it if we can.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
vtcarol50 (09-12-2010)
Old 09-12-2010, 11:31 PM   #3
Repairing Chandelier
I will post pictures as soon as I can.
Old 09-13-2010, 07:58 AM   #4
Rewards Points: 1,512
I think you start by "unscrewing" a finial or nut or circular ring at the very bottom of the chandelier.
There are probably a number of hexagonal nuts inside that look like rings that would fit a child's little finger (don't actually put them on anybody's finger). Undoing these will let more and more chandelier parts come undone and you can reach into the hub and tighten yet more of these ring nuts to tighten up the chandelier arms that are loose.
You may need to undo some wire nuts to get enough working room and/or slack to get parts out of the way.
Remember (or write down) what you undid one step at a time, and put labels on wires, so you can put it all back together.
The Following User Says Thank You to AllanJ For This Useful Post:
vtcarol50 (09-13-2010)
Help for mounting a British chandelier in the US PaliBob Electrical 7 12-16-2009 11:00 PM
heavier chandelier??? frgwtchr Electrical 13 07-25-2009 11:08 AM
Installing a chandelier preciouschristy Electrical 2 07-06-2009 04:35 AM
Wiring the bottom of a chandelier maged Electrical 12 06-04-2009 01:36 PM
need help with chandelier kreynolds Electrical 4 11-05-2008 09:40 PM
