Repace Door Chime - 10V Instead Of 16V - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 05:13 PM   #1
repace Door Chime - 10V instead of 16V
any idea where to find 10V 2-tone replacement door chime? I cannot acces transformer to change it to 16V
poboy is offline   Reply With Quote
Old 02-05-2011, 09:58 AM   #2
Rewards Points: 1,448
Measure the voltage across the wires that go to the chime with one of the wires disconnected from the chime and when someone pushes the button.
It is possible for a loose connection or a chime that draws lots of power to show a voltage of 10V when everything is connected and the system really is a 16V system.
Old 02-06-2011, 04:23 PM   #3
Electrical Contractor
kbsparky's Avatar
In the olde days, many of the cheaper "builder's model" of door chimes utilized 10 Volt transformers. Installing a new 16 volt model on a 10 volt system will result in poor performance -- a weak sounding chime, if at all.
You SHOULD have access to that transformer. Do you know where it is, and why do you not have access?
The builder's models these days all come with 16 Volt units. I don't know if there are any of the older 10 Volt units available anymore ...
-KB
