Removing Walls - How To Re-do The Electrical? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2008, 03:52 AM   #1
Rewards Points: 1,016
Removing walls - how to re-do the electrical?
I am planning to remove a couple (non load bearing) interior walls as part of a remodel - they of course contain switches and outlets. The switches will be relocated to adjacent walls.
  1. Those wires that will be unused, and just need to be terminated - how to properly do this?
  2. Those switches that need to be relocated, if needed how do I properly add wire length to get them to the new location?
thx!
Vince
Old 10-29-2008, 07:23 AM   #2
Is there an attic above this space? You could put junction boxes up there. If you don't have one, you could cut the wire at an accessible location, and run new wire. The problem is, you cannot put splices behind sheet rock.
rgsgww is offline   Reply With Quote
Old 10-29-2008, 08:39 AM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
thx!
Vince
I just had 2 extend 2 wires. I was able to get both of the old wires into the attic and added a junction box for each of them, then ran the new wire back in where I needed them.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-29-2008, 12:31 PM   #4
Call somebody on this one.
Have it all ready for him and it will be a couple hundred dollars well spent.
Homeowners motto:
One wire, hook it up.
Two wires, look it up
Three wires, eff it up
220/221 is offline   Reply With Quote
removing knockdown texture from painted interior walls skdahl General DIY Discussions 6 04-11-2008 11:02 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
Removing Outdoor Electrical Service scchang Electrical 5 08-15-2007 11:24 AM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 06:31 AM
