Removing Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 12:46 PM   #1
removing walls
I have a small closet the middle of a room that has a cold air return, thermostat and electric. I want to remove it to open up the space after we determine if it is a load barring wall I want to know if we can take it out and move everything else? And how much would it be?
duxtupelo1 is offline   Reply With Quote
Old 07-17-2010, 01:06 PM   #2
I=E/R
a7ecorsair's Avatar
Is this a one story house or two story house. Is there an unfinished basement or accessible crawl space. It helps to know what is above and below the room because it may be necessary to pull wires. Add some more detail after you determine if the wall is load bearing.
a7ecorsair is offline   Reply With Quote
Framing Garage walls and removing door Ziggy CS Carpentry 4 12-10-2009 06:08 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Removing wall under stairs Lankston Building & Construction 3 06-10-2008 08:50 AM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 07:31 AM
