Removing Unused Telecom Lines Outside The House? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 12:50 PM   #1
buckybadger's Avatar
Rewards Points: 85
Removing unused telecom lines outside the house?
The two lowest hanging lines across my backyard are phone lines that aren't in service. My inclination would be to just have them removed entirely, but the problem is that I don't know who to call since I've never used the lines while living in this house. What's the best way to proceed?
buckybadger is offline   Reply With Quote
Old 01-01-2012, 01:02 PM   #2
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Call the loca TELCO and request that they remove their service drops from your property.
HIVOLT is offline   Reply With Quote
The Following User Says Thank You to HIVOLT For This Useful Post:
plummen (01-01-2012)
Old 01-01-2012, 01:16 PM   #3
Rewards Points: 87
Find out who is the local TelCo and ask to have them removed. Everything up to and including the NID (Network Interface Device--small box where the transition from the drop to your inside wiring occurs) is the property of the telephone company.
The local TelCo is probably CenturyLink, now. Probably used to be Qwest. Check the NID. There might be identification in or on that.
Good luck. Getting today's TelCo out for a repair is hard enough. Getting them to remove something that, in their eyes, isn't broken, well...
There may be a downside to having those removed. If ever you want TelCo-supplied broadband, they may charge you to reinstall one. Heck, the way TelCos behave, these days, they may want to charge you to remove the ones that are there.
Jim
More Power! is offline   Reply With Quote
Old 01-01-2012, 01:22 PM   #4
MarginallyQualified
Rewards Points: 2,464
It would seem that the consensus is to NOT snip the wire at the house end, coil the wires up back to the pole, run some tape around the spool to hold it all tight and then hang that from a nail driven into the pole. hmmm.
Old 01-01-2012, 01:26 PM   #5
Rewards Points: 87
Old 01-01-2012, 01:35 PM   #6
Ironlight's Avatar
Jim
If you wait a bit and then order broadband they'll likely be running fiber instead of copper, and they'll probably do it for free. Verizon here in the NE is slowly rolling out fiber all over and they hooked up the house we bought 6 months ago and took down the existing copper when I asked them to, both at no charge.
And yeah, I would just cut the old wire and coil it up and attach it to the pole.
Ironlight is offline   Reply With Quote
Old 01-01-2012, 01:40 PM   #7
Rewards Points: 87
Don't bet on it. VZ is the only U.S. TelCom that did any wide-scale FTTx deployment, and that's basically at a standstill atm.
Jim
Old 01-01-2012, 01:52 PM   #8
Rewards Points: 85
Yeah, I guess I can start with Centurylink. I'm sure they'll be really happy to come alter lines when I'm not even a customer of theirs.
Maybe I'm young and naive, but I don't really see the value in a dedicated phone line. My house has Comcast/DirecTV coming in so in my mind that's more than adequate as far as data goes. One of these lines looks like it could be the original from the 1950's. When I traced it inside the house it just dead ended at an old Western Electric telephone block in the basement.
Maybe a future homeowner would detest the lack of a hard line, but it's a serious problem when we play ladder golf in the backyard and the bolos are getting caught on the phone lines!
Old 01-01-2012, 01:58 PM   #9
Rewards Points: 85
Well, I don't want to do anything illegal, now. In the event that someone were working on the pole down the road they would be able to tell fairly easily that these coiled up lines came from my house. I'm not someone who is afraid to cut some wires - I pull electrical permits for work I do on my own house - but messing with stuff at the pole doesn't seem like a great idea to me.
Old 01-01-2012, 02:03 PM   #10
Rewards Points: 87
You can say a lot about TelCos, these days, most of it deservedly uncomplimentary, but one thing is true: To this day, little is more reliable than good ol' POTS (Plain Old Telephone Service). During The Great Northeastern Blackout, a few years ago, the only reliable communications around here was SBC's POTS lines.
And y'know what? I bet if CL turned that circuit up and you hooked a phone to it, it'd probably just up and work.
All that being said: POTS is on its way out. If you've no use for it, you've no use for it. Hell, I'm nearly as old as the hills. Grew up with black rotary phones, with real ringers, and exchanges that started with a pair of letters (LIncoln, in my family's case). You could call 411 and actually get information. 611 would get you repair. But even I am about done with POTS.
Jim
Old 01-01-2012, 02:05 PM   #11
Rewards Points: 101
If you own the house I don't see why you can't at least ask them to remove the service drops. It'd hesitate to take them down yourself because those drops technically are property of the telephone company, not the homeowner.
michaelson is offline   Reply With Quote
The Following User Says Thank You to michaelson For This Useful Post:
gregzoll (01-01-2012)
Old 01-01-2012, 02:18 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Actually that is what I would do. That being said: I am a retired Telco emplyee and hung many of those drop wires and am very familiar with any risks involved. I would omit the nail and tape them to the pole.
Coastal South Carolina
Old 01-01-2012, 02:24 PM   #13
MarginallyQualified
The nail was already there.
Old 01-01-2012, 02:50 PM   #14
Rewards Points: 6,652
I still have the coax drop for Comcast on my house. Reason being, is that it is easier to just leave well enough alone, then undo it. Plus if at anytime I get tired of ATT U-Verse, I can hook back up to the Coax with very little interruption. I would leave well enough be, due to at sometime providers may decide to start charging people for running drops, especially if you switch back.
Old 01-01-2012, 04:25 PM   #15
Rewards Points: 85
Granted, but I have no plans to touch my Comcast/DirecTV connections. I was talking about phone lines that were existing to the house when I bought it, but that I have never utilized. Out of the coaxial, poco, and two phone lines, the two phone lines hang the lowest. I have a small city lot backyard so four wires crossing the middle of the yard is not only an eyesore, but as I mentioned, can interfere with intense games of ladder golf.
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Connect Air Cond Drain to House Waste lines AdamOJ Plumbing 19 11-23-2011 06:47 AM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
